How to view WLC AVC Stats
johnlloyd_13
Level 9
Level 9
hi,
i just created an AVC on a WLC3504 to block video streaming, i.e. youtube, netflix, amazon prime.
it's already enabled and applied to an SSID. how to do i check stats for the dropped traffic?
i saw stats/charts under monitor > applications > WLAN > application statistics, but not sure if it's due to the AVC policy drop.
is it only possible to view AVC dropped traffic via netflow or using cisco prime infra?
i also saw there's another way to do it: downloading an NBAR package file and enabling this feature.
is it this the same or an alternative approach?
balaji.bandi
best if you have Prime Infrastructure.
or you can follow below link :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/AVC_dg7point5.html
BB
