07-03-2021 01:29 PM
I'm trying to connect an HP Laser 107w printer to an Aironet 1815i AP. The AP is running latest Mobility Express Firmware 8.10.151.0. The WLAN is configured with basic settings (WPA2 PSK). The printer won't connect. Other devices have no issues connecting to this WLAN. And the printer does connect to a non-Cisco consumer AP just fine.
On the ME client dashboard, the printer's status is shown as "Excluded". Since the printer has no advanced WLAN settings at all, I'm trying to figure out which AP settings might work. The PSK has no special characters. See event log below for details.
Thanks for any hints!
21:53:55 Dot11 INFO ASSOC_REQ MESSAGE_RECEIVED None 21:53:55 Dot11 INFO ASSOC_REQ INVALID_RSN_IE None 21:53:55 PEM INFO PEM_EVENT_MSG IP_ACQUIRED_AND_AUTH_NOT_REQ_OR_STATIC_DYNAMIC_WEP_SUPPORTED None 21:53:55 Dot11 INFO ASSOC_REQ CLIENT_MOVED_TO_ASSOCIATED_STATE None 21:53:55 Dot1x ERROR AUTH_DOT1X WLAN_REQUIRES_802_1X_AUTH None 21:53:55 Dot1x ERROR EAPOL_KEY UNABLE_TO_ALLOW_USER None 21:53:55 Misce ERROR MISC_ROAM_EVENTS 00:00:00:00:00:00, 1,18:80:90:fb:98:60, 1, KEY_HS_TIMEOUT 21:53:55 Dot1x ERROR EAPOL_KEY UNABLE_TO_ALLOW_USER None 21:53:55 Misce ERROR MISC_ROAM_EVENTS 00:00:00:00:00:00, 1,18:80:90:fb:98:60, 1, KEY_HS_TIMEOUT 21:53:55 Dot11 ERROR AUTH_RES NOT_FROM_RELAY slot 0 (claller 1x_ptsm.c:693) 21:53:55 Dot1x ERROR EAPOL_KEY RETRANSMITTING_EAPOL_KEY None 21:53:55 Misce ERROR MISC_ROAM_EVENTS 00:00:00:00:00:00, 1,18:80:90:fb:98:60, 1, KEY_4WAY_TIMEOUT 21:53:55 Dot1x ERROR EAPOL_KEY IDENTITY_PACKET_RECEIVED None 21:54:00 Dot11 INFO ASSOC_REQ MESSAGE_RECEIVED None 21:54:00 Dot11 INFO ASSOC_REQ INVALID_RSN_IE None 21:54:00 PEM INFO PEM_EVENT_MSG IP_ACQUIRED_AND_AUTH_NOT_REQ_OR_STATIC_DYNAMIC_WEP_SUPPORTED None 21:54:00 Dot11 INFO ASSOC_REQ CLIENT_MOVED_TO_ASSOCIATED_STATE None 21:54:00 Dot1x ERROR AUTH_DOT1X WLAN_REQUIRES_802_1X_AUTH None 21:54:05 Dot1x ERROR EAPOL_KEY UNABLE_TO_ALLOW_USER None 21:54:05 Misce ERROR MISC_ROAM_EVENTS 00:00:00:00:00:00, 1,18:80:90:fb:98:60, 1, KEY_HS_TIMEOUT 21:54:05 Dot1x ERROR EAPOL_KEY UNABLE_TO_ALLOW_USER None 21:54:05 Misce ERROR MISC_ROAM_EVENTS 00:00:00:00:00:00, 1,18:80:90:fb:98:60, 1, KEY_HS_TIMEOUT 21:54:05 Dot1x ERROR EAPOL_KEY START_MESSAGE_RECEIVED None 21:54:05 Dot1x ERROR EAPOL_KEY TIMER_EXPIRES None 21:54:05 PEM ERROR PEM_EVENT_MSG DOT_802_1X_AUTH_SUCCESS None 21:54:05 Dot1x ERROR EAPOL_KEY DUPLICATE_IDENTITY_PACKET_RECEIVED None 21:54:05 Misce ERROR MISC_ROAM_EVENTS 00:00:00:00:00:00, 1,18:80:90:fb:98:60, 1, KEY_HS_PSK_MISMATCH
07-03-2021 09:36 PM
Re-check the settings. Error message says something is failing 802.1x authentication.
07-14-2021 06:38 PM
Thanks @Leo Laohoo,
The WLAN is definitely configured with WPA2 PSK AES. I even created a new WLAN for testing. These error messages apparently are not exclusive to 802.1x WLANs [1].
A debug on the CLI shows this relevant section:
Jul 15 01:36:18.816: f8:0d:ac:eb:a1:da Starting key exchange to mobile f8:0d:ac:eb:a1:da, data packets will be dropped Jul 15 01:36:18.816: f8:0d:ac:eb:a1:da Sending EAPOL-Key Message to mobile f8:0d:ac:eb:a1:da state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00 Jul 15 01:36:18.816: f8:0d:ac:eb:a1:da Allocating EAP Pkt for retransmission to mobile f8:0d:ac:eb:a1:da Jul 15 01:36:19.959: f8:0d:ac:eb:a1:da 802.1x 'timeoutEvt' Timer expired for station f8:0d:ac:eb:a1:da and for message = M2 Jul 15 01:36:19.960: f8:0d:ac:eb:a1:da Retransmit 1 of EAPOL-Key M1 (length 99) for mobile f8:0d:ac:eb:a1:da Jul 15 01:36:20.951: f8:0d:ac:eb:a1:da 802.1x 'timeoutEvt' Timer expired for station f8:0d:ac:eb:a1:da and for message = M2 Jul 15 01:36:20.951: f8:0d:ac:eb:a1:da Retransmit 2 of EAPOL-Key M1 (length 99) for mobile f8:0d:ac:eb:a1:da Jul 15 01:36:21.943: f8:0d:ac:eb:a1:da 802.1x 'timeoutEvt' Timer expired for station f8:0d:ac:eb:a1:da and for message = M2 Jul 15 01:36:21.944: f8:0d:ac:eb:a1:da Retransmit failure for EAPOL-Key M1 to mobile f8:0d:ac:eb:a1:da, retransmit count 3, mscb deauth count 0 Jul 15 01:36:21.944: f8:0d:ac:eb:a1:da Resetting MSCB PMK Cache Entry @index 0 for station f8:0d:ac:eb:a1:da Jul 15 01:36:21.944: f8:0d:ac:eb:a1:da Removing BSSID 18:80:90:fb:98:6a from PMKID cache of station f8:0d:ac:eb:a1:da Jul 15 01:36:21.944: f8:0d:ac:eb:a1:da Setting active key cache index 0 ---> 8 Jul 15 01:36:21.945: f8:0d:ac:eb:a1:da 4way handshake timeout, send deauth and cleanup the mscb
And this is what it looks like when a different client successfully connects to the same WLAN:
Jul 15 01:52:16.731: d4:f5:47:76:00:3c Starting key exchange to mobile d4:f5:47:76:00:3c, data packets will be dropped Jul 15 01:52:16.731: d4:f5:47:76:00:3c Sending EAPOL-Key Message to mobile d4:f5:47:76:00:3c state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00 Jul 15 01:52:16.731: d4:f5:47:76:00:3c Allocating EAP Pkt for retransmission to mobile d4:f5:47:76:00:3c Jul 15 01:52:16.733: d4:f5:47:76:00:3c validating eapol pkt: key version = 2 Jul 15 01:52:16.734: d4:f5:47:76:00:3c Received EAPOL-Key from mobile d4:f5:47:76:00:3c Jul 15 01:52:16.734: d4:f5:47:76:00:3c key Desc Version FT - 0 Jul 15 01:52:16.734: d4:f5:47:76:00:3c Received EAPOL-key in PTK_START state (message 2) from mobile d4:f5:47:76:00:3c Jul 15 01:52:16.734: d4:f5:47:76:00:3c Encryption Policy: 4, PTK Key Length: 48 Jul 15 01:52:16.734: d4:f5:47:76:00:3c Successfully computed PTK from PMK!!! Jul 15 01:52:16.734: d4:f5:47:76:00:3c Received valid MIC in EAPOL Key Message M2!!!!!
Some sources (like [2]) suggest tuning eapol-key-timeout (default is 1 second). I tried 5 seconds (config advanced eap eapol-key-timeout 5000), but unfortunately this didn't fix it.
Other ideas?
[1] https://community.cisco.com/t5/wireless/psk-wlan-and-802-1x-auth-failure/td-p/3995673
[2] https://support.hpe.com/hpesc/public/docDisplay?docId=c01785322
07-14-2021 07:32 PM
It feels like the client did not reply to the authentication message.
I think adjusting the EAP parameters on the one hand, on the other hand, you can try an OEPN SSID to see if it is caused by the encryption algorithm and whether it is compatible with the client's network card
07-15-2021 04:04 AM
An open SSID works, but is not a viable solution. What other EAP parameters could I adjust?
07-15-2021 04:46 AM
Can you share the detailed config of the SSID with a "show wlan id <WLAN_ID>" output?
07-15-2021 05:36 AM
Thanks for your help @JPavonM. This is the WLAN I created for testing:
WLAN Identifier.................................. 2 Profile Name..................................... hp Network Name (SSID).............................. hp Status........................................... Enabled MAC Filtering.................................... Disabled Broadcast SSID................................... Enabled Random MAC Filtering............................. Disabled AAA Policy Override.............................. Disabled Network Admission Control Client Profiling Status Radius Profiling ............................ Disabled DHCP ....................................... Disabled HTTP ....................................... Disabled Local Profiling ............................. Disabled DHCP ....................................... Disabled HTTP ....................................... Disabled Radius-NAC State............................... Disabled SNMP-NAC State................................. Disabled Quarantine VLAN................................ 0 Maximum Clients Allowed.......................... Unlimited Security Group Tag............................... Unknown(0) Maximum number of Clients per AP Radio........... 200 ATF Policy....................................... 0 Number of Active Clients......................... 1 Number of Active Random-Mac Clients.............. 0 Exclusionlist Timeout............................ 180 seconds Session Timeout.................................. 86400 seconds User Idle Timeout................................ Disabled Sleep Client..................................... disable Sleep Client Timeout............................. 720 minutes Sleep Client Auto Auth Feature................... Enabled Web Auth Captive Bypass Mode..................... Enabled User Idle Threshold.............................. 0 Bytes NAS-identifier................................... none CHD per WLAN..................................... Enabled Webauth DHCP exclusion........................... Disabled Interface........................................ management Multicast Interface.............................. Not Configured WLAN IPv4 ACL.................................... unconfigured WLAN IPv6 ACL.................................... unconfigured WLAN Layer2 ACL.................................. unconfigured mDNS Status...................................... Disabled mDNS Profile Name................................ unconfigured DHCP Server...................................... Default DHCP Scope Name.................................. none Central NAT...................................... Disabled Central NAT Peer-Peer Blocking................... Disabled DHCP Address Assignment Required................. Disabled Static IP client tunneling....................... Disabled Tunnel Profile................................... Unconfigured EoGRE Override VLAN state........................ disable EoGRE Override VLAN ID........................... 0 Quality of Service............................... Silver Per-BSSID Rate Limits............................ Upstream Downstream Average Data Rate................................ 0 0 Average Realtime Data Rate....................... 0 0 Burst Data Rate.................................. 0 0 Burst Realtime Data Rate......................... 0 0 Per-Client Rate Limits........................... Upstream Downstream Average Data Rate................................ 0 0 Average Realtime Data Rate....................... 0 0 Burst Data Rate.................................. 0 0 Burst Realtime Data Rate......................... 0 0 Per-WLAN Rate Limits............................. Upstream Downstream Average Data Rate................................ 0 0 Average Realtime Data Rate....................... 0 0 Burst Data Rate.................................. 0 0 Burst Realtime Data Rate......................... 0 0 Scan Defer Priority.............................. 4,5,6 Scan Defer Time.................................. 100 milliseconds WMM.............................................. Allowed WMM UAPSD Compliant Client Support............... Disabled Media Stream Multicast-direct.................... Disabled CCX - AironetIe Support.......................... Enabled CCX - Gratuitous ProbeResponse (GPR)............. Disabled CCX - Diagnostics Channel Capability............. Disabled Dot11-Phone Mode (7920).......................... Disabled Wired Protocol................................... 802.1P (Tag=0) Passive Client Feature........................... Disabled Peer-to-Peer Blocking Action..................... Disabled Radio Policy..................................... All DTIM period for 802.11a radio.................... 1 DTIM period for 802.11b radio.................... 1 Radius Servers Authentication................................ Global Servers Accounting.................................... Global Servers Interim Update............................. Enabled Interim Update Interval.................... 0 Framed IPv6 Acct AVP ...................... Prefix Authorization ACA............................. Disabled Accounting ACA................................ Disabled Dynamic Interface............................. Disabled Dynamic Interface Priority.................... wlan Local EAP Authentication......................... Disabled Radius NAI-Realm................................. Disabled Radius Authentication caching.................... Disabled Mu-Mimo.......................................... Enabled Security 802.11 Authentication:........................ Open System FT Support.................................... Disabled Static WEP Keys............................... Disabled 802.1X........................................ Disabled Wi-Fi Protected Access (WPA/WPA2/WPA3)........ Enabled WPA (SSN IE)............................... Disabled WPA2 (RSN IE).............................. Enabled WPA3 (RSN IE).............................. Disabled WPA2/WPA3 Encryption Ciphers TKIP Cipher............................. Disabled CCMP128/AES Cipher...................... Enabled CCMP256 Cipher.......................... Disabled GCMP128 Cipher.......................... Disabled GCMP256 Cipher.......................... Disabled OSEN IE.................................... Disabled Auth Key Management 802.1x.................................. Disabled 802.1x-SHA2............................. Disabled PSK..................................... Enabled PSK-SHA2................................ Disabled CCKM.................................... Disabled FT-1X(802.11r).......................... Disabled FT-PSK(802.11r)......................... Disabled OSEN-1X................................. Disabled SUITEB-1X............................... Disabled SUITEB192-1X............................ Disabled OWE..................................... Disabled SAE..................................... Disabled PMKID in 4way-handshake.................... Disabled OWE Transition Mode........................ Disabled OWE Transition Mode WLAN id................ 0 Auto Key PSK .............................. Disabled FT Reassociation Timeout................... 20 FT Over-The-DS mode........................ Disabled GTK Randomization.......................... Disabled SKC Cache Support.......................... Disabled CCKM TSF Tolerance......................... 1000 Wi-Fi Direct policy configured................ Disabled EAP-Passthrough............................... Disabled CKIP ......................................... Disabled Web Based Authentication...................... Disabled Web Authentication Timeout.................... 300 Web-Passthrough............................... Disabled Mac-auth-server............................... 0.0.0.0 Web-portal-server............................. 0.0.0.0 qrscan-des-key................................ Conditional Web Redirect...................... Disabled Splash-Page Web Redirect...................... Disabled Auto Anchor................................... Disabled FlexConnect Local Switching................... Enabled FlexConnect Central Association............... Disabled flexconnect Central Dhcp Flag................. Disabled flexconnect nat-pat Flag...................... Disabled flexconnect Dns Override Flag................. Disabled flexconnect PPPoE pass-through................ Disabled flexconnect local-switching IP-source-guar.... Disabled FlexConnect Vlan based Central Switching ..... Disabled FlexConnect Local Authentication.............. Disabled FlexConnect Learn IP Address.................. Enabled Flexconnect Post-Auth IPv4 ACL................ Unconfigured Flexconnect Post-Auth IPv6 ACL................ Unconfigured Client MFP.................................... Optional PMF........................................... Disabled PMF Association Comeback Time................. 1 PMF SA Query RetryTimeout..................... 200 Tkip MIC Countermeasure Hold-down Timer....... 60 Eap-params.................................... Disabled AVC Visibilty.................................... Disabled Flex Avc Profile Name............................ hp OpenDns Profile Name............................. None OpenDns Wlan Mode................................ ignore OpenDns Wlan Dhcp Option 6....................... disable Flow Monitor Name................................ None Split Tunnel Configuration Split Tunnel................................. Disabled Call Snooping.................................... Disabled Roamed Call Re-Anchor Policy..................... Disabled SIP CAC Fail Send-486-Busy Policy................ Enabled SIP CAC Fail Send Dis-Association Policy......... Disabled KTS based CAC Policy............................. Disabled Assisted Roaming Prediction Optimization......... Disabled 802.11k Neighbor List............................ Disabled 802.11k Neighbor List Dual Band.................. Disabled 802.11v Directed Multicast Service............... Disabled 802.11v BSS Max Idle Service..................... Disabled 802.11v BSS Transition Service................... Enabled 802.11v BSS Transition Disassoc Imminent......... Disabled 802.11v BSS Transition Disassoc Timer............ 200 802.11v BSS Transition OpRoam Disassoc Timer..... 40 802.11v BSS Transition Neigh List Dual Band...... Disabled DMS DB is empty Band Select...................................... Disabled Load Balancing................................... Disabled Multicast Buffer................................. Disabled Universal Ap Admin............................... Disabled Broadcast Tagging................................ Disabled PRP.............................................. Disabled Fast Receive..................................... Disabled 11ax Downlink MU-MIMO............................ Disabled 11ax Uplink MU-MIMO.............................. Disabled 11ax Downlink OFDMA.............................. Disabled 11ax Uplink OFDMA................................ Disabled 11ax Admin state................................. Enabled Wifi Alliance Multiband Operation................ Disabled 11ax Target Wake Time............................ Enabled Advanced Scheduling Requests..................... Disabled Mobility Anchor List WLAN ID IP Address Status Priority ------- --------------- ------ -------- 802.11u........................................ Disabled MSAP Services.................................. Disabled Local Policy ---------------- Priority Policy Name -------- --------------- QoS Fastlane Status.............................. Disable Selective Reanchoring Status..................... Disable Lobby Admin Access............................... Disabled Fabric Status -------------- Fabric status.................................... Disable Vnid Name........................................ Vnid............................................. 0 Applied SGT Tag.................................. 0 Peer Ip Address.................................. 0.0.0.0 Flex Acl Name.................................... Flex IPv6 Acl Name............................... Flex Avc Policy Name............................. U3-Interface................................... Disable U3-Reporting Interval.......................... 30
07-15-2021 07:21 AM
Your debug points to a compatibility issue with some security feature in the client side, but this is not the case as you have all of them disabled (PMF, FT), try disabling some features added on latest versions that could cause connectivity problems such as dot11ax (I think device-analytics is not there on AireOS). Additionally, disable 5 GHz radio as most if not all printers works on 2.4 GHz band only.
wlan <PROFILE> id <ID> <SSID>
no device-analytics
no dot11ax
radio dot11bg
- Jesus
07-15-2021 06:00 PM
The printer indeed doesn't support 5 GHz, but setting the radio policy to 2.4 GHz only doesn't make a difference. I had tried that before.
I checked the Mobility Express Command Reference [1]. Unfortunately, none of your suggested settings seem to be supported.
The embedded radio module (SDGOB-1392) seems to be used by many HP printers and there are quite a few reports about compatibility issues with Aironet APs. Enabling TKIP seems to work for some users, but I really don't want to go there.
[1] https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/cmd_ref/me_cr_book-810.html
07-14-2021 08:51 PM
Means the WLC is sending M1 for the 3rd time but no response back.
07-15-2021 04:26 AM
But why? As mentioned, the printer connects to other APs just fine (also with WPA2 PSK). And all my other devices work with the Cisco AP. But there is nothing I could change on the printer side. It has the latest firmware and absolutely no advanced WLAN settings. So I have to find a workaround / compatibility setting on the AP.
07-15-2021 05:12 AM
Factory-reset the AP.
07-14-2021 10:51 PM
Can you check if 802.11w-PMF is enabled or optional in the SSID? I've suffered this very same behaviour with some devices that state they are PMF-capable but they aren't.
- Jesus
07-15-2021 05:39 AM
"Client MFP" says "Optional", but "PMF" says "Disabled". Please see full config above.
