Need Help!!!!!!!!
yasib ahmed
Level 3
Level 3
Hii
i am try to convert AIR-AP1041N-E-K9 autonomous to Lightweight (Controller Base). i was successfully upgraded but it can not find the WLC IP.
I don't know why it happen. i have also check the switch and found it is fine and DHCP is enable.
i have also create a DHCP pool in my WLC.
But still it can find any IP address via WLC.
It shows the following error:
*Dec 17 11:27:49.827: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Please check the attachments.
Regard
Yasib
2 Accepted Solutions
HI Yasiba,
AP Model: AIR-AP1041N-E-K9: Its for europe domain
WLC configured with : US country code
its mismatch of the country code.
Option:
1. Either use any Europe country on wlc to join this AP
2. Or Buy another AP with -A- domain, example: AIR-AP1041N-A-K9
Dont forget to rate helpful posts
Here are the commands:
1. first you need to disable radios
(WLC) >config 802.11a disable network
(WLC) >config 802.11b disable network
2. Then use this command to configure multiple country code on LC:
(WLC) >config country US,DE,.....
3. And then enable both radios again:
(WLC) >config 802.11a enable network
(WLC) >config 802.11b enable network
More info on my post: https://rscciew.wordpress.com/2014/02/08/country-code-on-wlc/
Info:Running multiple country codes in a single WLC is not a good idea. by doing this,the only common channels will be allowed. Power will also be curtailed to the most common one. One thing to remember when running multiple country codes is that you always run the lowest common setting. You could improve things by splitting the APs up by country and only run specific countries on certain controllers.
18 Replies 18
Rasika Nayanajith
You can try statically configure IP on your AP (via console) & see if that helps.
http://mrncciew.com/2013/03/17/ap-registration/
Below is sample CLI commands required, change IP details according to your scheme.
capwap ap ip address 10.10.113.5 255.255.255.0
capwap ap ip default-gateway 10.10.113.1
capwap ap controller ip address 10.10.111.10
Rasika
*** Pls rate all useful responses ***
Can anyone help me to get download the latest version of AIR-AP1041N-E-K9  Lightweight IOS for free.
Because from Cisco website it requires a service contract, which i have none.
Thank you
Lightweight IOS, the RCV, does NOT require a valid Service Contract to download.  Contact Cisco TAC and they'll publish the file.
Hello Leo
I can't download  any Lightweight IOS form Cisco. i contact with them via online support but they told me that they are support only SMB product and it is Enterprise level product.
so how can i solve this problem??
Send an email to [email protected] and provide serial numbers to your WLC and your APs.
Thank you....
Hello Leo,
Can you help me to find the answer of following questions???
I would like to know the capability of the Cisco Wireless controller model: 2504 about…
  1.          Guest access control
  2.          Access token for guest with expiration
  3.          Administrator Monitoring facilities and reports
  4.          Seamless access and AD authentication
  5.          DHCP management
  6.          Details of the service level and annual maintenance.
Hello Manannalage,
It show the following message.
%CAPWAP-5-SENDJOIN: sending Join Request to 192.168.2.99
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
 %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.2.99:5246
*Dec 20 07:47:46.933: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Dec 20 07:47:46.964: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 20 07:47:47.932: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
AP IP: 192.168.2.91
subnet:255.255.254.0
Defaul gateway: 192.168.2.1
WLC IP: 192.168.2.99
WLC & AP are connected with same switch & under the same Vlan (Vlan 30).
From Ap it can ping to WLC. From switch AP and WLC can be pingable.
But the AP can not registered with WLC. I don't know where's  the problem.
Post the complete output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time; and
3.  AP:  sh version
Hey Leo,
Here is the AP sh version output:
APbc16.65d6.629c#sh ver
Cisco IOS Software, C1040 Software (C1140-K9W8-M), Version 15.3(3)JBB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 04-May-15 19:01 by prod_rel_team
ROM: Bootstrap program is C1040 boot loader
BOOTLDR: C1040 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA6, RELEASE SOFTWARE (fc1)
APbc16.65d6.629c uptime is 35 minutes
System returned to ROM by reload
System image file is "flash:/c1140-k9w8-mx.153-3.JBB/c1140-k9w8-xx.153-3.JBB"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-LAP1041N-E-K9 (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL18S
PowerPC405ex CPU at 333Mhz, revision number 0x147E
Last reset from reload
LWAPP image version 8.1.102.0
1 Gigabit Ethernet interface
1 802.11 Radio
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: BC:16:65:D6:62:9C
Part Number                          : 73-14034-06
PCA Assembly Number                  : 800-3273-07
PCA Revision Number                  : A0
PCB Serial Number                    : FOC10FFS
Top Assembly Part Number             : 800-344-05
Top Assembly Serial Number           : FGL1717
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1041N-E-K9
Configuration register is 0xF
And please check the attachment for WLC show command
HI Yasiba,
Option:
HI Sandeep,
You are actually right. Now i have found the problem
it was actually the Country code problem with WLC and AP.
Here's the solution link.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_01110111.html
Now it works perfectly.
I have one question, if i have several types of AP models, then how can i  add more country code on WLC??
Can you please give me the CLI command on how to add more country code on WLC??
Thank you for your help it worked perfectly.
Following commends i need to put on my AP and WLC, this will help others too.
Summary:
For Lightweight AP:
#debug capwap console cli
#erase /all nvram:
#reload
#capwap ap ip address
192.168.2.90 255.255.254.0
#capwap ap ip default-gateway 192.168.2.1 #capwap ap controller ip address 192.168.2.99
For WLC-2504:
(WLC) >config country US,BE,.....
(WLC) >save config
(WLC) >show ap summary
(WLC) >show country
(WLC) >show country supported
