HREAP and DHCP
Hi All,
I have a Cisco 4402 wireless controller and I am trying to set up HREAP to dump traffic off locally.  I have the HREAP function working as I can see my wireless MAC address on the correct vlan in the MAC table on various switches.  The problem, the Wireless NIC isn't recieving a DHCP address.  I have verified that my pool is operational.  I connected a laptop to the same switch that the WAP is connected to and it pulls an IP address from that VLANs DHCP pool.
What am I missing?  Another question is what interface to I set up for this WLAN?  If it is going to be at a remote office, what should it be set to?
Chris
8 Replies 8
Stephen Rodriguez
I would build a dummy interface and link the WLAN to that.  That way if something goes wrong they can't go anywhere.
As for HREAP/FlexConnect do you have the WLAN mapped to the VLAN on the AP?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
on the AP properties it is mapped. WLAN ID 4 to VLAN id 14.  And I know that part is working because my Wireless NIC Mac is showing up on the right VLAN in the switch.
Can you post the config of the switchport the AP is connected to?
Steve
HTH,
Steve
interface FastEthernet0/2
switchport trunk native vlan 13
switchport mode trunk
speed 100
duplex full
end
The native line is for the WAPs DHCP Config.
fb_webuser
Level 6
Level 6
did you enable hreap with local switching under the wlan which you wouwould be using
Posted by WebUser Danny Borpatragohain from Cisco Support Community App
Chris,
     Can you screen shot the AP config?
Steve
HTH,
Steve
fb_webuser
Level 6
Level 6
also under hreap ap check under HREAP option and see if the native vlan is the one y
I went to go add a virtual interface on VLAN 14 and that brought down my access to the WLC.  I rebooted and now I can pull IP addresses at my office.  I have this WLAN in my Corporate office and now it is working just fine.  I have now applied this WLAN to a remote office WAP (will be using the same vlan, just differnet subnet) and it won't pull an IP address.  Again, I can see the MAC address on the swtich that is directly connected to the router with the IP Helper address and it still can't pull an IP address.  This is a different switch from which the WAP is connected.  If I plug a laptop into the same switch that the WAP is connected to, it pulls an IP address not problem.
