HTTP and HTTPS not working
Actually i am working on 8510 WLC and suddenly I can't access the WLC via https nor http even though are enabled
I checked the certificate validity of webadmin it shows that expired 2024 but WLC time is 2022 amd actually also new access points not joining
24 Replies 24
Thank you for advice and will try with reboot WLC
1- do you have and vedio or doucoment explain how to regenrate the local certificate i searched but not found
2- regarding access points hard reset will resolve the issue or the only solution to install  8.0.152.0 AP code (153-3.JA12) as you mentioned ?
  - @Turki.A.Baqatada     1- do you have and vedio or doucoment explain how to regenrate the local certificate
                                       The command was already provided to you in the thread :
                                                    config certificate generate webadmin
           For item 2 :  yes , that is the only solution
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
If you want the documentation for that command then see the config guide:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/administration_of_cisco_wlc.html#ID523
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Thank you brother i am going to downgrade the AP that can join back the 8510 WLC and i have some questions
1- I just want to confirm my wlc version is 8.0.152.0 AP version will be (153-3.JA12) as you mensioned and choose
WIRELESS LAN
ap3g2-k9w8-tar.153-3.JA12.tar
if you can provide the command will be great
2- as the ap joined the 9800 WLC will take credentials from WLC so ineed to configure SSH and username/password from AP join profile (device) tab to enable (user) tab to configure username/password ?
3- Regarding version does country code matter or it is one for all
________
thank you for your support and wants to know is there any thing else I should do
The expired Web Admin certificate is very likely related to both issues.
If the WLC clock is showing 2022 while the webadmin certificate expired in 2024, the controller may be using an invalid time, which can cause certificate validation problems. Modern browsers may refuse the HTTPS connection because of the certificate status, and an incorrect system time can also affect CAPWAP DTLS certificate validation, preventing new APs from joining.
A few things to check:
  • Verify the WLC date, time, and NTP configuration.
  • Check whether the MIC/SSC certificates used for AP authentication are still valid (show certificate all).
  • Try accessing the GUI with another browser or in a private/incognito window to rule out cached certificate issues.
  • Confirm whether SSH or the CLI is still accessible. If it is, you can inspect the webadmin certificate and regenerate it if necessary.
  • Check the AP join failure reason with commands such as show ap join stats summary all or show ap join stats detailed <AP_Name>, and review the controller logs for certificate or DTLS errors.
Could you also share:
  • The WLC software version (8.x release)?
  • The output of show certificate all
  • The output of show time
  • Any messages from debug capwap events enable or the AP join logs?
Those details will help determine whether the issue is only the web GUI certificate or whether expired AP/DTLS certificates are also preventing new APs from joining.
aleabrahao
Meraki Community All-Star
Is this generated by AI?
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
That was my first thought too @aleabrahao
@hellencharless54 seems oblivious to the field notices and the need to turn the clock back (with NTP off) to match old certs.
Well they're almost certainly expired by now for older Aironet APs - that's the whole point of the field notices @hellencharless54
How can i know mic /ssc certificates i show certificate all
For web admin it is expired since 2023 but i configured the wlc time to 2022 as i faced this issue before with only joining aps not accessing the wlc via browser  i did this and was succeeded with disabling ntp but now i can not login also found some access points or new one not joining too
Regarding join state i found error is join message decode maximum message size failed
  • Verify the WLC date, time, and NTP configuration. Time is 11 jul 2022
  • Check whether the MIC/SSC certificates used for AP  authentication are still valid (show certificate all). How do I check I typed show certificate all is there any thing here i can focus
  • Try accessing the GUI with another browser or in a private/incognito window to rule out cached certificate issues. I tried with no luck
  • Confirm whether SSH or the CLI is still accessible. If it is, you can inspect the webadmin certificate and regenerate it if necessary. SSH WORKING AND WEB ADMIN VALID TILL 2023 IF NEEDS TO REGENERATE HOW I DO THIS AND IS THERE ANY IMPACT
  • Check the AP join failure reason with commands such as show ap join stats summary all or show ap join stats detailed <AP_Name>, and review the controller logs for certificate or DTLS errors. JOIN MESSAGE DECODE MAXIMUM MESSAGE SIZE FAILED
  • The WLC software version (8.x release)?8.0.152.0
  • TIME............…............ Mon jul 11 18:19:53 2022
  • FOR CISCO SHA1 DEVICE CERT EXPIRE ON 2023  SO BASED ON CONTROLLER TIME STILL VALID
  • COULD BE CERTIFICATE OF AP IT SELF?
@Turki.A.Baqatada please read my previous reply (above) and provide the requested information?
The other reply you are reacting to (which looks to be AI generated) is of limited use - has some valid points and some not.
