HTTPS access issue at 3500
Leftz
Level 9
Level 9
Hi We have wlc 3500. Please see the below. HTTPS is enabled, but why we cannot access via https? Thank you very much.
19 Replies 19
Mark Elsen
                 - What error are you getting in the browser ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leftz
Level 9
Level 9
Thanks marce1000 for your reply. Please see the below. and http has no problem.
 - Make sure no ACL's are in place on the controller that restrict certain components from administrative access , for that when using http check/verify  the the WLC GUI and choose Security > Access Control Lists
 M.
Change the browser and try again
Leftz
Level 9
Level 9
Other browser has the same issue
The WLC has some ACL, but the management interface that we are using for access does not associate with any ACL.
Cpu acl ? Share it here if yes.
               - For sanity check remove/clear all acl's (temporarily)
 M.
Leftz
Level 9
Level 9
No cpu acl
and all ACLs are related with ISE and Guest wifi. Other wlc has the same ACL as this one.
 - Check logs on the controller when https access is tried 2) Make sure no intermediate firewall blocks https access to the controller , 3) Fetch the (https)  page with wget ,( https://linuxize.com/post/wget-command-examples/ ) , check if you can find  additional errors.
 M.
then this is not effect access to WLC.
in PC share the output of following
telnet <WLC3500> port <443>
let see if there is any FW block the port in way to WLC.
Rasika Nayanajith
Are you trying to access it while connecting to wireless or from wired LAN? By default access via wirelessly is blocked.
As long as you have IP reachability from your LAN to WLC, you should be able to access from wired connected PC
Rasika
Thanks for this point.
Rich R
Have you tried Deleting and Regenerating the self signed certificate? (followed by reload)
Or re-installing the public certificate (followed by reload) if you're using a public cert?
If still not working get a packet capture of the connection to see why it's closing the connection.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
