HWIC 3G GSM on a Cisco 2921
Peter Valdes
Level 3
Level 3
We have a Cisco 2921 running IOS 15.1(4)M4 with UC license package.
I connected a HWIC 3G GSM EHWIC slot but is not getting recognise under CLI. I read the HWIC 3G is supported on 2900 series ISRs.
Am I missing something, or does this require additional step to enable interface cellular x/x/x?
GW#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
HO-TATA-GW uptime is 6 weeks, 20 hours, 18 minutes
System returned to ROM by reload at 04:34:46 UTC Tue Sep 18 2012
System restarted at 04:36:05 UTC Tue Sep 18 2012
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL1635123T
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          FGL1635123T
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
Mate, we use this a lot for our backup links but as a VPN not as telstra direct so we have a username/password in our dialer which authenticates with our radius. It should work but yea GSM is bit old and we use 3G-HSPA.
Make sure you put in the chatscript and apply it on the line interface
Router#cell 0/0/0 gsm profile create 1 telstra.internet chap dummy dummy
Router(config)#chat-script NextG "" "ATDT*98*1#" TIMEOUT 60 "CONNECT"
Router(config)#line 0/0/0
Router(config-line)#script dialer NextG
Router(config-line)#endRouter(config)#line 0/0/0
interface Cellular0/0/0
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 1
async mode interactive
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string NextG
dialer persistent
dialer-group 1
ppp authentication chap callin
ppp chap hostname dummy
ppp chap password 0 dummy
check your NAT / Routing configs.
Also make sure the SIM is unlocked (if it is locked by a PIN) using the telstra software and disable the PIN.
Good luck
Stephen Rodriguez
What type of HWIC 3G is it? you may need to run a T train.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7272/product_data_sheet0900aecd80600f41.html
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Hi Steve,
On the module, it states HWIC-3G-GSM V01.
We are able to get a 2811 router and its working. Using a Telstra SIM with a mobile number, any configuration for this?
No username and password require for the dialer interface.
no ip address
encapsulation ppp
dialer in-band
interface Dialer0
encapsulation ppp
dialer pool 1
dialer string NextG
dialer persistent
dialer-group 1
Good luck
