HWIC-3G-HSPA UP/DOWN
missengineer
I have a problem about HWIC-3G-HSPA card.Line protocol is becoming always up/down and there is message on screen "Mailbox msg transmit failure".
Is there any opinion about failure and how can I solve this issue?
I am sharing soma screenshots from config.
Thank you
missengineer
Any comment???
patoberli
This is the Wi-Fi forum, typically we can't help you much here.
What I can see from the log, your HWIC module is flapping down and up, which causes various other issues.
Have you tried a reboot?
Is the software and maybe HWIC firmware up to date?
Do you have enough signal strength where this device stands?
Maybe you need to reseat the module and sim card.
Dear,
Thank you for suggestions. I have solved it. card was fail. Changed it. But now I have new problem. Cellular IP changes contionusly.
It get Ip and change after 10 min or if I reload router.
What I should check in my configuration?
chat-script HSPA "" "ATDT*98#" TIMEOUT 30 CONNECT
interface Cellular0/3/0
 ip address negotiated
 ip nat outside
 ip virtual-reassembly
 encapsulation ppp
 dialer in-band
 dialer idle-timeout 0
 dialer string HSPA
 dialer-group 2
 async mode interactive
 ppp chap hostname cisco
 ppp chap password 7 14141B180F0B
 ppp ipcp dns request
ip sla 100
 icmp-echo 94.79.93.248  (this was previous IP and changed )
 threshold 2000
 timeout 2000
 frequency 2
ip sla schedule 100 life forever start-time now
access-list 2 permit any
dialer-list 2 protocol ip permit
line 0/3/0
 exec-timeout 0 0
 script dialer HSPA
 login
 modem InOut
 no exec
 transport preferred none
 transport input all
 transport output all
 rxspeed 7200000
 txspeed 2000000
line 0/3/1
 no exec
 rxspeed 7200000
 txspeed 2000000
Dear all,
Maybe someone need the answer. Card was fail. I changed it and then problem solved.
fyi
