We have 3G WAN HWIC card on the 2801 Cisco routers.For some reasons ( loosing its static ip ) we want to reload HWIC card.We do not want to reload router.Is there any command to reload HWIC card only ?
If all you want to do is bounce a cellular modem card, you can run a command like the following. I don't know what interface you're using, so edit as needed.
test cellular 0/0/0 modem-power-cycle
Learn, share, save
