I accidentally added an interface to the wrong interface group on 5508
bjohnson04
Frequent Visitor
Frequent Visitor
    Interface abc to our guest interface group.  I tried disabling the abc WLAN and then removing it from the group but that didnt work.  Im still get the error "Interface group is being used by WLAN"
What do I need to do to remove this interface?
Rasika Nayanajith
Temporary map different interface to WLAN (under AP group & global WLAN config) & then go under interface group & remove the unwanted interface. Then you can remap the interface group to the WLAN
Rasika
*** Pls rate all useful responses ***
Hi @Rasika Nayanajith
What is the impact of perform the suggested action?
I assuming that this will lead to WLAN being unavailable while the interface group is remapped causing outage!
Yes obviously so should be done during a maintenance window @magNHS
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
 Hopefully you dont have this interface group added to many AP group . I did the same mistake already and I had the interface group  in about 100 AP groups. I had to use a spreadsheet to run all AP group deleting and interface group. Then taking off on interface and adding the interface group back in all AP groups again.
