I need technical assistance; Please advise
alkelsey2000
Beginner
Beginner
Hello community. I am installing an ANT-4G-OMNI-out-N  4G antenna and need a compatible lightning arrester. I currently have an arrester (model # 4G-ACC-OUT-LA) however it doesn't connect to the female connector on the antenna. I'm sure that I can find an adapter to interface the two but I want to be certain that this model  is appropriate for use with the antenna. Please advise with info and suitable part numbers if able. Thanks!
jagan.chowdam
Enthusiast
Enthusiast
ANT-4G-OMNI-out-N has N-Type female. So, you need N-Type male to Female
Accessories
Table 10. Cisco Lightning ArrestorsCisco PIDConnectors TypeArrestor Type and Frequency Range (MHz)
CGR-LA-NM-NF
N(m)-STR to N(f)-STR
DC to 6000 MHz GDT typeSupports active GNSS antennas, passes DC
ACC-LA-H-NM-NF
698 to 2700 MHzHigh power, ultra low shunt impedance, HPF typeDoes not pass DC, no support for active GNSS antennas
CJ
/**Please rate useful responses**/
