I need Upgrade WiSM to 7.0.235.3
Juan Ibañez
I have a 6509-E with Sup WS-SUP720-3B IOS (s72033-ipservicesk9_wan-mz.122-18.SXF7)
And i need upgrade my Wism to software version 7.0.235.3, and i have a question:
 I have to update the ios Supervisor? or can i upgrade to 7.0.235.3 with  Supervisor IOS version 12.2(18).SXF7?
Sandeep Choudhary
There is no need to update the IOS for superviser.
You can upgrade the software for wism.
Dont forget to rate helpful posts
Sandeep Choudhary
Ok, Thanks Sandeep, but Cisco have any document for compatibility for Wism version and Sup 720 IOS Version?
Hi Juan,
No I did not find any specific documents about there compatibility.
The firmware of the IOS does not decide your 6500 Supervisor. If you want to use WiSM-1, regardless of the firmware you have inside, then your supervisor card should be a Sup720 running IOS version SXF2
So dont worry about this and go ahead with wism software upgrade.
wism last support is 7.0.x .
