I want to deploy Cisco CMX, Cisco Prime Inf to monitor
Do Tien Dung
My company's campus infrastructure uses devices
Switches C9200, C2960, SG-300
Distribute 4507R-E, 3750
AP: AIR-AP1852I-SK9, WLC 3504
Will Cisco CMX and Cisco Prime Inf support my company's devices?
I want to get the implementation document and its OVA file ? Thank you team,
Thanks & Best Regards,
Do Tien Dung
Technical staff - Service support department
IT Operations Center
57 Huynh Thuc Khang Street, Dong Da District,
Ha Noi Capital, Viet Nam
www.vnptit.vn
live:.cid.edce5e4917b06b34
For the wireless side there is the compadibility matrix
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
As others have said there is EOL notices to ake into account. But from your list dependant on software versions they should be supported
*****Help out other by using the rating system and marking answered questions as "Answered"*****
5 Replies 5
marce1000
  - Note for starters that https://www.cisco.com/c/dam/m/en_emear/internet-of-everything-ioe/mobility/pdfs/en-05-cmx-sol-brief-cte-en.pdf focuses on WiFi performance and analysis. For the wired devices (cisco switches)  Cisco Prime offers flexible management and also alerting with various handlers being supported ,
 M.
Rich R
Keep in mind the end of support dates for your hardware. For example:
3504  https://www.cisco.com/c/en/us/products/collateral/wireless/3504-wireless-controller/eos-eol-notice-c51-744737.html
2960 already end of support: https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-series-switches/eos-eol-notice-c51-730121.html
And Prime itself already has EOL announced:
https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-infrastructure/prime-infrast-gen-appliance-lic-eol.html
So do you really want to implement something which is approaching end of life?
Anyway, if you do want to, then you need to contact your Cisco account manager or your local Cisco reseller to get a quote.
 Cisco Prime is about to die soon and CMX is already dead.
 Both tools are now DNAC and DNAC Space respectivelly.
Thanks you,@Flavio Miranda @Rich R
I have built it successfully, I will refer to DNAC
Do Tien Dung
www.vnptit.vn
