IBM laptops loss connectivity with AP1200
ouslu
Our customer have IBM laptops(A30P) with onboard wireless cards.( High Rate Wireless MiniPCI Combo card, Actiontec Electronics, Inc ( Manufacturer), PRISM Wireless LAN).
I configured static web encryption with 128 bit encryption. Clients loss connectivity to the wireless APs time to time then they reconnect. Has anybody faced this problem before?
Okan
Not applicable
Try to change the clear channel assessment method setting to energy detect(the default setting is carrier correlation) in the ACU and see the issue is resolved.
We are not using ACU at our customer because they are wireless adaptors are not Cisco. Only using window's wireless settings.
Okan
