05-09-2007 04:06 AM - edited 07-03-2021 02:02 PM
Hello all
I have a little Wireless netwok ( 1 WLC 2200 and 6 AP 1100 series )and since few days I have the following message :" IDS Signature attack detected. Signature Type:Standard, Name: Assoc flood, Description: Association Request flood, Track:per-signature, Detecting AP Name: AP3, Radio Type: 802.11b/g, Preced:4,Hits: 50, Channel: 6, srcMac: 00:16:6F:49:C6:8A " and don't know how to resolve !
Help is welcome !
Thanks a lot
05-09-2007 04:13 AM
What version of code are you running on the 2002?
05-09-2007 01:27 PM
I just received the following from TAC today:
In regards to the "IDS 'Disassoc flood' Signature attack detected on AP" log, please refer to following bug:
Title:
IDS:AP impersonation alerts against own AP mac address
Symptom:
WLC is reporting AP impersonation alerts for the same MAC address of the AP.
Tha MAC address corresponds to the first WLAN configured
AP Impersonation with MAC 'xx:xx:xx:xx:xx:xx' is detected by authenticated AP 'xx:xx:xx:xx:xx:xx' on '802.11b/g' radio and Slot ID '0'.
The event can be triggered if AP can hear itself due to RF conditions, and there is no AP authentication enabled in controllers
Workaround:
Enable "AP Authentication feature" and trigger set to 2.
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsg44344 (Requires CCO Login)
Please go into your controller GUI>>Security>>Wireless Protection
Policies>>AP Authentication/MFP and for Protection Type set that to AP
Authentication and trigger set to 2
05-09-2007 02:41 PM
Wow, I was also getting these alerts. I just implemented the suggestion and will see how it goes.
10-05-2007 11:46 AM
I am running MFP on my WLC.
I recieved the same error message with MFP anomolies (NO MIC). Under wireless peotecion policies I have MFP enabled. Should I disable MFP and change it to AP authentication?
