07-09-2023 10:04 PM
HI all,
we are using Cisco 9800 Controller and 9130 Access points.
we are getting Radio Down in 5GHz alert in DNAC, How to resolve the issue.
07-09-2023 10:45 PM
- Check the status of the Radio(s) on the controller (too).
M.
07-12-2023 08:36 AM
And if it is down on the WLC then why?
- Does the AP have enough power?
- Is it configured correctly?
- Is the country configured correctly?
- Is the AP the correct regulatory domain for the country?
Have you checked the controller config with https://cway.cisco.com/wireless-config-analyzer/ using the output of "show tech wireless"?
07-13-2023 02:39 AM
Issue Solved,
on Port AP getting the Power in 15w and one radio is down, so I changed the port to other poe switch. now it is working fine.
