increase signal strength
john smith
Dears,,
how to increase the signal strength of cisco cap3602i  access point from controller..
i have deployed this series in a hotel and some area signals are very week even some times no signal at all,, so i decided to increse signal strength.
can any one guide me that how i can do this from controller??
much appriciated in advance
THANKS
You can do this via GUI or CLI.
First of all check what is the current power level of your 3600 AP radio bands. You can set it to maximum (level 1) which will override the DTPC values.
(WLC) > show ap config 802.11a
Tx Power
      Num Of Supported Power Levels ............. 5
      Tx Power Level 1 .......................... 14 dBm
      Tx Power Level 2 .......................... 11 dBm
      Tx Power Level 3 .......................... 8 dBm
      Tx Power Level 4 .......................... 5 dBm
      Tx Power Level 5 .......................... 2 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 4
      Tx Power Assigned By ...................... DTPC
(WLC) >show ap config 802.11b
    Tx Power
      Num Of Supported Power Levels ............. 7
      Tx Power Level 1 .......................... 22 dBm
      Tx Power Level 2 .......................... 19 dBm
      Tx Power Level 3 .......................... 16 dBm
      Tx Power Level 4 .......................... 13 dBm
      Tx Power Level 5 .......................... 10 dBm
      Tx Power Level 6 .......................... 7 dBm
      Tx Power Level 7 .......................... 4 dBm
      Current Tx Power Level .................... 7
Here how you can change it Tx power of a individula AP
(WLC) >config 802.11a txPower ?
global         Configures all 802.11a Cisco APs.
ap             Configures one 802.11a Cisco APs.
(WLC) >config 802.11a txPower ap ?
     Enter Cisco AP name
(WLC) >config 802.11a txPower ap ap ?
global         Enables auto-RF.
  Enter transmit power level
(WLC) >config 802.11a txPower ap 1
(WLC) >config 802.11b txPower ap   1
You can change it via GUI as well.(Wireless -> 802.11a/n| 802.11b/g/n -> AP -> Configure -> Tx Power Level Assignment ->Custom -> Level 1)
Rasika
*** Pls rate all useful responses ****
Leo Laohoo
1.   Do you have autonomous or controller-based access points?
2.   Describe how you deployed and installed your APs?  Are they hidden inside ceiling spaces?
3.  What signal strengths are you getting (802.11a) when you are, say, 10 metres away from the AP?
