RAM Size for the 5508 and 5760 Wireless LAN Controllers
gadhadhargupta
Hello experts,
What is the RAM size for the 5508 and 5760 Wireless LAN Controllers?
Gadhadhar
Sandeep Choudhary
Hi Gadhadhar,
Its around 512MB.
Please use this command to check:
show memory statistics (to see the memory)
Dont forget to rate helpful posts.
Here is the output from one of our 5760 & 5508. It is looks like my 5508 is having 1GB & 5760 is having 10GB of RAM.
5760-1#sh version
cisco AIR-CT5760 (i686) processor with 10485760K bytes of physical memory.
Processor board ID FOC1727V0MT
2 Virtual Ethernet interfaces
6 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
255000K bytes of Crash Files at crashinfo:.
3612840K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of  at webui:.
(5508) >show memory statistics
System Memory Statistics:
Total System Memory............: 1027411968 bytes
Used System Memory.............: 563486720 bytes
Free System Memory.............: 463925248 bytes
Bytes allocated from RTOS......: 73573184 bytes
Chunks Free....................: 249 bytes
Number of mmapped regions......: 59
Total space in mmapped regions.: 311734272 bytes
Total allocated space..........: 71516232 bytes
Total non-inuse space..........: 2056952 bytes
Top-most releasable space......: 490840 bytes
Total allocated (incl mmap)....: 385307456 bytes
Total used (incl mmap).........: 383250504 bytes
Total free (incl mmap).........: 2056952 bytes
This would be a good comparison data sheet for all controllers (even it does not contain RAM information), refer that if you are comparing two products
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/at_a_glance_c45-652653.pdf
Rasika
**** Pls rate all useful responses ****
jepatil
Hi guys,
It is indeed accurate that we have 8GB of DDR3 DRAM off an Intel i5 mobile CPU on the 5760.
Best Regards,
Jeevan
Senior Product Line Manager
Wireless Networking Group
Hi Jeevan,
Thanks for that info +5.
I have an query what it shows in the show version output. If it is 8GB it should say 8388608 K bytes (8*1024*1024) of RAM instead of 10485760K bytes or 10GB
Does this 5760 comes with 10GB (8+2) or just 8GB of RAM ?
Rasika
