04-03-2013 03:55 AM - edited 07-03-2021 11:49 PM
I've ugraded one ap cisco 1136AG fron ap to lwapp, but if I telnet the device it answer me "password reuqired but not set"
It's correct?
At the moment I'm not able to access phisically the ap but with the command sh cdp nei on the switch i see :
Device ID: AP0024.1444.ebb2.cisco.com
Entry address(es):
IP address: 192.168.110.221
Platform: cisco AIR-AP1131AG-E-K9 , Capabilities:
Interface: GigabitEthernet1/0/6, Port ID (outgoing port): FastEthernet0
Holdtime : 151 sec
Version :
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.4(10b)JDA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 30-Oct-08 11:33 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 12.200 Watts
Power request id: 45202, Power management id: 1
Power request levels are:12200 9910 9750 6200 0
Management address(es):
the image C1130-RCVK9W8-M), it's an lwapp image or not?
thanks in advance
giancarlo
Solved! Go to Solution.
04-03-2013 04:30 AM
That is a lwapp image. You can't telnet or ssh unless you enable that on the WLC when the AP has joined the WLC successfully. The WLC is the device that provides the configuration to the access point. If you don't have a WLC, then you need to use an autonomous AP.
04-03-2013 04:30 AM
04-03-2013 04:59 AM
Many thanks!!!
I've a controller my question was only because at the moment I'm not able to access to the Lwapp console.
now I'm triyng to access the lwapp and configure it to ip , gw and the basic parameters.
Thanks for help
Giancarlo
04-03-2013 05:01 AM
No you will not be able to. Best thing to do is setup a DNS entry to resolve cisco-capwap-controller.yourdomain.com to the management IP of the WLC. Or else place the AP in the same subnet as the WLC management interface. Then let it join and your done:)
