init>> prompt on 1562E Access Point - wait to press 4 - need help
kholod
Please help me to set default board  profile in init
AP1562E , on boot show
Please choose one of the following boards:
1. 3K
2. 2K (new)
3. 2K (proto)
4. Milos
5. 2KH
6. 3KVE (v-sku)
7. 3KH/3KA/4K
8. Duplo
init>>
if i press 4 - it boot ok
How to set default board profile ?
i don't have prog_pid in available command
PLEASE Help
BootROM - 1.78
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
Detected Device ID 6920
Master bootloder version 1.34
1. 3K
2. 2K (new)
3. 2K (proto)
4. Milos
5. 2KH
6. 3KVE (v-sku)
7. 3KH/3KA/4K
8. Duplo
after i press 4
init>> High speed PHY - Version: 2.0
BoardId = 0x23board SerDes lanes topology details:
| Lane # | Speed| Type |
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
:** Link is Gen1, check the EP capability
PCIe, Idx 1: Link upgraded to Gen2 based on client cpabilities
PCIe, Idx 2: Link upgraded to Gen2 based on client cpabilities
High speed PHY - Ended Successfully
DDR4 Training Sequence - Ver TIP-0.23.(Sublib 0.8)0
DDR4 Training Sequence - Switching XBAR Window to FastPath Window
DDR4 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
BootROM: Boot image signature verification PASSED
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2013.01-gacaad15 (Aug 18 2019 - 20:12:19) SDK version: 2015_T2.0p10
Board: Milos
SoC: MV88F6920 Rev A1
running 2 CPUs
CPU: ARM Cortex A9 MPCore (Rev 1) LE
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DDR4 32 Bit Width,FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM: 1 GiB
RST I2C0
NAND: 256 MiB
SF: Detected N25Q32A with page size 64 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
PCI-e 1 (IF 0 - bus 0) Root Complex Interface, Detected Link X1, GEN 2.0
PCI-e 2 (IF 1 - bus 1) Root Complex Interface, Detected Link X1, GEN 2.0
Map: Code: 0x3fed9000:0x3ffadc40
BSS: 0x3ffef704
Stack: 0x3f9c8f20
Heap: 0x3f9c9000:0x3fed9000
U-Boot Environment: 0x00100000:0x00110000 (SPI)
Board configuration:
| port | Interface | PHY address |
| egiga1 | SGMII | 0x01 |
SFP not detected, enable RJ45
Net: , egiga1 [PRIME]
Hit ESC key to stop autoboot: 0
Hit ESC key - to go u-bot
u-boot>>
u-boot>> version
arm-openwrt-linux-uclibcgnueabi-gcc (OpenWrt GCC 4.7.1 r48430) 4.7.1
GNU ld (GNU Binutils) 2.24.0
u-boot>> dump_board_env
Board env is unconfigured
u-boot>>
How to set board env ?
resetenv - i try this, not working
full help command list in attach
kholod
OK.
Finlay i downgrade bootloader to oldest i can find 2016Y (version 1.06) don't know why number look 1.6
BootROM - 1.78
Master bootloder version 1.6
===it is actualy 1.06===
BoardId = 0x20board SerDes lanes topology details:
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
U-Boot 2013.01-g7a7330d (Mar 24 2016 - 18:15:30) Marvell version: 2015_T2.0p10
Board: Barbados-3K
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
Error writing to the chip.
NAND: 256 MiB
===yes error and crc===
Map: Code: 0x3fede000:0x3ffadc28
BSS: 0x3ffef640
Stack: 0x3f9cdf20
Heap: 0x3f9ce000:0x3fede000
| egiga2 | SGMII | In-Band |
Port1: phyAddr=0x1, Not Marvell PHY id1 ffff id2 ffff
PHY error - shutdown port1
Net: , egiga1, egiga2 [PRIME]
u-boot>
Unknown command 'ry 'help'
Board ID: 3K
===HERE we see wrong board type====
Flags=00000000
EM Ignore: 0
EM Blacklist : pid=00000000, mask=00000000
EM Whitelist : pid=00000000, mask=00000000
u-boot>> help
? - alias for 'help'
Creset - Creset - Run 'reset' or boot command in a loop, while counting.
SatR - Sample At Reset sub-system
active_units- print active units on board
askenv - get environment variables from stdin
base - print or set address offset
bdinfo - print Board Info structure
boardinit- Downlod and execute board initialization script
boot - boot default, i.e., run 'bootcmd'
bootd - boot default, i.e., run 'bootcmd'
bootelf - Boot from an ELF image in memory
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
bootvx - Boot vxWorks from an ELF image
bootz - boot Linux zImage image from memory
bubt - bubt - Burn an image on the Boot flash device.
chpart - change active partition
clear_board_env- Clears board env
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
date - get/set/reset date & time
ddrPhyRead- ddrPhyRead - Read DDR PHY register
ddrPhyWrite- ddrPhyWrite - Write DDR PHY register
dhcp - boot image via network using DHCP/TFTP protocol
dma - dma - Perform DMA using the XOR engine
dump_board_env- Dump board env
echo - echo args to console
editenv - edit environment variable
efuse - eFuse manipulation subsystem for secure boot mode
env - environment handling commands
exit - exit script
ext2load- load binary file from a Ext2 filesystem
ext2ls - list files in a directory (default /)
ext4load- load binary file from a Ext4 filesystem
ext4ls - list files in a directory (default /)
ext4write- create a file in the root directory
false - do nothing, unsuccessfully
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
fdt - flattened device tree utility commands
fsinfo - print information about filesystems
fsload - load binary file from a filesystem image
go - start application at address 'addr'
help - print command description/usage
i2c - I2C sub-system
iminfo - print header information for application image
imxtract- extract a part of a multi-image
init_aquantia_phy-
init_aquantia_phy -- DEFAULT AQ_FW_LOADADDR=0x4000000
ir - ir - reading and changing MV internal register values.
itest - return true/false on integer compare
ledstate- Set Led State
loadb - load binary file over serial line (kermit mode)
loads - load S-Record file over serial line
loadx - load binary file over serial line (xmodem mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
map - map - Display address decode windows
md - memory display
me - me - PCIe master enable
mm - memory modify (auto-incrementing address)
mp - mp - map PCIe BAR
mtdparts- define flash/nand partitions
mtest - simple RAM read/write test
mvEthPortCounters- Port counter
mvEthPortMcastShow- Port multicast counter
mvEthPortRegs- Neta register values
mvEthPortRmonCounters- Port RMON counter
mvEthPortUcastShow- Port unicast counter
mvEthRegs- Neta register values
mvNetComplexNssSelect- Neta register values
mvNetaGmacRegs- Neta register values
mvNetaPortRegs- Neta register values
mvNetaPortStatus- Neta register values
mvsource- mvsource - Burn a script image on flash device.
mw - memory write (fill)
nand - NAND sub-system
nandboot- boot Linux from NAND partition
nboot - boot from NAND device
neta_dump- Neta register values
netboot - boot Linux from network using TFTP/bootp
nfs - boot image via network using NFS protocol
nm - memory modify (constant address)
pci - list and access PCI Configuration Space
pciePhyRead- phyRead - Read PCI-E Phy register
pciePhyWrite- pciePhyWrite - Write PCI-E Phy register
phyRead - phyRead - Read Phy register
phyWrite- phyWrite - Write Phy register
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
prog_emblacklist- Program EM blacklist
prog_emignore- Program EM ignore
prog_emwhitelist- Program EM whitelist
prog_flags- Program board env flags
progpid - Program PID cookie
=== AND !!!! progpid and many other's======
pxe - commands to get and boot from pxe files
rcvr - rcvr - Start recovery process (with TFTP server)
reset - Perform RESET of the CPU
resetenv- resetenv - Erase environment sector to reset all variables to default.
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
se - se - PCIe Slave enable
setenv - set environment variables
sf - SPI flash sub-system
sg - sg - scanning the PHYs status
showvar - print local hushshell variables
sleep - delay execution for some time
source - run script from memory
sp - scan and detect all devices on PCI-e interface
sspi - SPI utility command
switchCountersRead- switchCntPrint - Read switch port counters.
switchPhyRegRead- - Read switch register
switchPhyRegWrite- - Write switch register
switchRegRead- switchRegRead - Read switch register
switchRegWrite- switchRegWrite - Write switch register
sysboot - command to get and boot from syslinux files
temp - temp - Display the device temperature.
tempCmd0- tempCmd - This command allocated for monitor extinction
tempCmd1- tempCmd - This command allocated for monitor extinction
tempCmd2- tempCmd - This command allocated for monitor extinction
tempCmd3- tempCmd - This command allocated for monitor extinction
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
training- training - prints the results of the DDR3 Training.
trainingStability- training - prints the results of the DDR3 Training.
true - do nothing, successfully
ts_report- ts_report - report touch screen coordinate
ts_test - ts_test - test touch screen
ubi - ubi commands
ubifsload- load file from an UBIFS filesystem
ubifsls - list files in a directory
ubifsmount- mount UBIFS volume
ubifsumount- unmount UBIFS volume
verify_bl- Cisco Bootloader signature verify
verify_lx- Cisco Image signature verify
version - print monitor, compiler and linker version
whoAmI - - reading CPU ID
xsmiPhyRead- xsmiPhyRead - Read Phy register through XSMI interface
xsmiPhyWrite- xsmiPhyWrite - Write Phy register through XSMI interface
u-boot>> help progpid
Usage:
progpid progpid 3k|2k|2kp1|milos
- set board's product id
u-boot>> progpid milos
...u-boot>> reset
resetting ...
====== SET !=====
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Milos
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
NAND: 256 MiB
BSS: 0x3ffef640
Stack: 0x3f9cdf20
Starting board initialization process. Proceed? [y/N]: y = my fault. did know what they want at this moment
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Retry count exceeded; starting again
BOOTP broadcast 1
*** Unhandled DHCP Option in OFFER/ACK: 42
*** Unhandled DHCP Option in OFFER/ACK: 43
DHCP client bound to address *******
Using egiga1 device
TFTP from server***************
Filename *************
Load address: 0x2000000
Loading: ##
1.6 MiB/s
done
Bytes transferred = 26759 (6887 hex)
## Executing script at 02000000
Wrong image format for "source" command
u-boot>> boot
Starting board initialization process. Proceed? [y/N]: n
Aborting board initialization...
Board ID: Milos
Flags=00000000
EM Ignore: 0
u-boot>> printenv
BOOT=part1
CASset=max
ENABLE_BREAK=1
MALLOC_len=5
MANUAL_BOOT=0
MEMORY_DEBUG=0
MPmode=SMP
autoload=yes
baudrate=9600
bootcmd=boardinit =======> WRONG!==== we should set correct
bootdelay=3
cacheShare=no
disaMvPnp=no
dnsip=**********
eeeEnable=no
enaClockGating=no
enaCpuStream=no
enaFPU=yes
enaMonExt=no
enaWrAllo=no
eth1addr=00:50:43:7a:ed:ea
eth1mtu=1500
eth2addr=00:50:43:7a:42:ea
eth2mtu=1500
ethact=egiga1
ethaddr=00:50:43:42:ed:ea
ethmtu=1500
ethprime=egiga1
fileaddr=2000000
filesize=6887
gatewayip=**********
image_name=part.bin
initrd_high=0xffffffff
ipaddr=*********
limit_dram_size=yes
loadaddr=0x02000000
loads_echo=0
mtddevname=fs
mtdids=nand0=armada-nand
mtdparts=mtdparts=armada-nand:1m(oops),1m(reserved),-(fs)
nandEcc=nfcConfig=4bitecc
netmask=255.255.255.0
netretry=yes
partition=nand0,2
pcieTune=no
pexMode=RC
serverip=**********
stderr=serial
stdin=serial
stdout=serial
yuk_ethaddr=00:00:00:EE:51:81
Environment size: 1008/65532 bytes
====WHAT we need ??=====
u-boot>> setenv bootcmd nandboot
u-boot>> boot
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: attached mtd1 to ubi0
UBI: MTD device name: "mtd=2"
UBI: MTD device size: 254 MiB
UBI: number of good PEBs: 2024
UBI: number of bad PEBs: 8
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 7
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 2024
UBI: number of PEBs reserved for bad PEB handling: 20
UBI: max/mean erase counter: 2081/903
UBIFS: mounted UBI device 0, volume 0, name "part1"
UBIFS: mounted read-only
UBIFS: file system size: 78217216 bytes (76384 KiB, 74 MiB, 616 LEBs)
UBIFS: journal size: 3936256 bytes (3844 KiB, 3 MiB, 31 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root: 3865560 bytes (3774 KiB)
Loading file 'part1/part.bin' to addr 0x02000000 with size 6335021 (0x0060aa2d)...
Done
Checking image signing.
This could take up to 40 seconds. Please wait...
Image signing verification success, continue to run...
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Barbados Firmware Image
Created: 2020-10-30 23:30:20 UTC
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 6334013 Bytes = 6 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 4203272 Bytes = 4 MiB
Image 1: 2114585 Bytes = 2 MiB
Image 2: 16137 Bytes = 15.8 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x02606774
Loading Multi-File Image ... OK
OK
reserving fdt memory region: addr=0 size=4000
Loading Device Tree to 00ff9000, end 00ffff08 ... OK
Starting Device Tree update ('fdt_skip_update' = no)
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:00.0000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[01/01/1970 00:00:00.0000] Memory: 1025836K/1048576K available (5743K kernel code, 407K rwdata, 2480K rodata, 359K init, 478K bss, 22740K reserved)
[01/01/1970 00:00:00.1200] CPU1: Booted secondary processor
[01/01/1970 00:00:01.4400] buginf tty flushing thread started, ttyport=bf0f3c00
[01/01/1970 00:00:01.5600] m25p80 spi1.0: found n25q032a, expected n25q032
[01/01/1970 00:00:03.7300] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:03.8200] lm75: probe of 2-0049 failed with error -110
[01/01/1970 00:00:05.9000] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:05.9900] lm75: probe of 2-004b failed with error -110
[01/01/1970 00:00:08.1300] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:10.2200] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:12.3100] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:14.4000] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:16.4900] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:18.5800] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:20.6700] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:22.7600] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:24.8500] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:26.9400] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:29.0300] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:31.1200] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:33.2100] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:35.3000] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[*01/01/1970 00:00:36.1588] buginf() enabled.
[*01/01/1970 00:00:36.1684] Made it into bootsh: Oct 30 2020 16:21:13 T-a9e4eaf8ccf0cad1ba59eaa8794b7332dbca2d5a-ga9e4eaf8-aut
[*01/01/1970 00:00:43.8364] bootsh mini ramfs booted /bootpart/part1/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
CUT
[*12/17/2020 18:05:46.8821]
[*12/17/2020 18:05:46.8821] [12/17/2020 18:6:26] Programming shadow with flash version 106Programming shadow with flash version 106Magic : 62 6F 6F 74 69 6E 66 6F
[*12/17/2020 18:05:46.8821] Master:
[*12/17/2020 18:05:46.8821] Version : 0x0106
[*12/17/2020 18:05:46.8821] Source : bundle
[*12/17/2020 18:05:46.8821] Retry : 0x1
[*12/17/2020 18:05:46.8821] Timestamp : 1608228324
[*12/17/2020 18:05:46.8821] Shadow:
[*12/17/2020 18:05:46.8821] Source : flash
[*12/17/2020 18:05:46.8822] Retry : 0x1
[*12/17/2020 18:05:46.8822] Timestamp : 1608228325
[*12/17/2020 18:05:46.8822] Blacklisted:
[*12[12/17/2020 18:05:48.0000] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
/17/2020 18:05:46.8822] Version : 0x0000
[*12/17/2020 18:05:46.8822] Source : unknown
[*12/17/2020 18:05:46.8822] [12/17/2020 18:6:47] Shadow is now in-synced with masterShadow is now in-synced with master<30>systemd[1]: Started Cisco btldr service.
===== Sync all to 106==========
[*12/17/2020 18:05:47.1672] parameter passed without an option given
[*12/17/2020 18:05:47.2249] /etc/init.d/S10boot: Warning: deleting backup ap images to save storage...
[*12/17/2020 18:05:47.2402] 7
[*12/17/2020 18:05:47.4171] Active version: 17.3.2.32
[*12/17/2020 18:05:47.4200] Backup version: 17.1.1.29
AP2C33.110E.82B8>en
Password:
CUT
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version
AP2C33.110E.82B8 uptime is 0 days, 0 hours, 4 minutes
Last reload time : Thu Dec 17 18:05:22 UTC 2020
cisco AIR-AP1562E-R-K9 ARMv7 Processor rev 1 (v7l) with 1028252/571272K bytes of memory.
Processor board ID FCZ2141Z0BA
AP Running Image : 17.3.2.32
Primary Boot Image : 17.3.2.32
Backup Boot Image : 17.1.1.29
Primary Boot Image Hash: 8b95adb12d84a0ab60af0e626f1beeafaa6afd403e375f9b2a20a2c5137ebaada872404472eb40aac5d708094124c1adaadf5ba6db1d6d9662dc98ae6e42d67e
Backup Boot Image Hash: 393f3a757c7fa1b8e8699e4c73d395dc5b7bd9a5a93b5c512bc0ec1f2fcdf6477e04648297b4b69a005e065cedfda38ab22a84efa18e8c590425d93f68ac8df3
1 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version : 2.4.28
Base ethernet MAC Address : 2C:33:11:0E:82:B8
Part Number : 73-100839-04
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC21363AGQ
Top Assembly Part Number : 068-100610-01
Top Assembly Serial Number : FCZ2141Z0BA
Top Revision Number : A0
Product/Model Number : AIR-AP1562E-R-K9
AP2C33.110E.82B8#reload
Proceed with reload? [confirm]
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Milos
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
NAND: 256 MiB
BSS: 0x3ffef640
Stack: 0x3f9cdf20
Done
Contents:
OK
Loading Device Tree to 01ff9000, end 01ffff08 ... OK
Starting kernel ...
[01/01/1970 00:00:01.4400] buginf tty flushing thread started, ttyport=be9b9000
[*01/01/1970 00:00:36.1590] buginf() enabled.
[*01/01/1970 00:00:36.1685] Made it into bootsh: Oct 30 2020 16:21:13 T-a9e4eaf8ccf0cad1ba59eaa8794b7332dbca2d5a-ga9e4eaf8-aut
[*01/01/1970 00:00:43.8397] bootsh mini ramfs booted /bootpart/part1/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
CUT
[ OK ] Created slice -.slice.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Reached target Cisco File Systems (Pre).
[ OK ] Listening on udev Kernel Socket.
[ OK ] Reached target Timers.
[ OK ] Listening on udev Control Socket.
[ OK ] Reached target Sockets.
[ OK ] Created slice system.slice.
Starting Cisco UBIFS reformat/mount...
[ OK ] Reached target Slices.
Starting udev Coldplug all Devices...
Starting udev Kernel Device Manager...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Cisco UBIFS reformat/mount.
Starting Cisco early mount...
[ OK ] Started Cisco early mount.
[ OK ] Reached target Local File Systems (Pre).
Starting Cisco seed generation...
Starting Cisco platform file generation...
Starting Cisco system time setup...
Starting Cisco fips check...
[ OK ] Started Cisco seed generation.
CUT
Cisco AP Software, (ap3g3), C1562, RELEASE SOFTWARE
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Fri Oct 30 16:24:33 PDT 2020
AP2C33.110E.82B8 uptime is 0 days, 0 hours, 2 minutes
Last reload time : Thu Dec 17 18:30:50 UTC 2020
Last reload reason : reload command
AP2C33.110E.82B8#ap-type mobility-express ******AIR-AP1560-K9-ME-8-10-142-0.tar
Starting download ME-AP image tftp://**********/AIR-AP1560-K9-ME-8-10-142-0.tar ...
It may take a few minutes. If longer, please abort command, check network and try again.
######## 11.7%[*12/17/2020 18:34:23.0003]
######################################################################## 100.0%
Image download completed.
Upgrading ...
upgrade.sh: Script called with args:[NO_UPGRADE]
do NO_UPGRADE, part1 is active part
upgrade.sh: Script called with args:[-c CHECK_ME]
do CHECK_ME, part1 is active part
upgrade.sh: Start doing upgrade arg1=CHECK_ME arg2=,from_cli arg3= ...
upgrade.sh: Using image /tmp/cli_part.tar on barbados ...
Image signing verify success.
[[*12/17/2020 18:35:04.5678] set cleanair [slot0][band0] enabled
[*12/17/2020 18:35:04.5718] set cleanair [slot1][band1] enabled
12/17/2020 18:35:55] Programming master with bundle version 134Programming master with bundle version 134Magic : 62 6F 6F 74 69 6E 66 6F
Master:
Version : 0x0134
Source : bundle
Retry : 0x1
Timestamp : 1608230094
Shadow:
Version : 0x0106
Source : flash
Retry : 0x1
Blacklisted:
Version : 0x0000
Source : unknown
[12/17/2020 18:36:15] Master now upgradedMaster now upgradedupgrade.sh: part to upgrade is part2
upgrade.sh: AP version1: part2 17.1.1.29, img 8.10.142.0
upgrade.sh: mount ubifs /dev/ubivol/part2 as /bootpart, status=0
upgrade.sh: Untar /tmp/cli_part.tar to /bootpart/part2...
upgrade.sh: Sync image to disk...
[*12/17/2020 18:35:31.6675] event-> CAC_EXPIRY_EVT
upgrade.sh: activate part2, set BOOT to part2
upgrade.sh: AP version2: part2 8.10.142.0, img 8.10.142.0
upgrade.sh: AP primary version: 8.10.142.0
upgrade.sh: Finished upgrade task.
upgrade.sh: Cleanup for do_upgrade...
upgrade.sh: /tmp/upgrade_in_progress cleaned
upgrade.sh: Cleanup tmp files ...
Successfully setup ME-AP image.
Archive done.
=== NOW 134=====
====AND fianl reboot NO ERROR====
[12/17/2020 18:35:43.2231] reboot: Restarting system
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Milos
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
RST I2C0
NAND: 256 MiB
BSS: 0x3ffef704
Stack: 0x3f9c8f20
UBIFS: mounted UBI device 0, volume 1, name "part2"
Loading file 'part2/part.bin' to addr 0x02000000 with size 6332465 (0x0060a031)...
Done
Created: 2020-11-04 16:10:17 UTC
Data Size: 6331457 Bytes = 6 MiB
Contents:
Image 0: 4203368 Bytes = 4 MiB
Image 1: 2111936 Bytes = 2 MiB
Booting using the fdt at 0x02605d78
OK
Starting kernel ...
[01/01/1970 00:00:00.0000] Memory: 1025848K/1048576K available (5743K kernel code, 407K rwdata, 2472K rodata, 359K init, 478K bss, 22728K reserved)
[01/01/1970 00:00:01.4300] buginf tty flushing thread started, ttyport=bf2aa400
[01/01/1970 00:00:01.5500] m25p80 spi1.0: found n25q032a, expected n25q032
[*01/01/1970 00:00:02.5790] buginf() enabled.
[*01/01/1970 00:00:02.5886] Made it into bootsh: Nov 4 2020 06:57:45 T-a9e4eaf8ccf0cad1ba59eaa8794b7332dbca2d5a-ga9e4eaf8-aut
[*01/01/1970 00:00:12.7554] bootsh mini ramfs booted /bootpart/part2/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
ooooo thanks for genius advice throw away my ap
21 Replies 21
marce1000
  When falling back to that prompt it means that the ap has a hardware problem. RMA the ap
 M.
kholod
AP is working
accept init waiting prompt
so, i need help to set default
anyway, i don't have warranty for this ap as it expired
                         - The ap falls back to this prompt because it has a basic hardware problem -> replace it.
 M.
Dear marce1000
i will make situation more clear - it falls back to this prompt because one of my stuff did not right thing
in u-boot it did
After it fallback to prompt
So, i need info HOW to set default board type, and asking help for this
I am sorry, but replace AP - very ease answer, as i mention before, i don't have warranty on it, and i know that reason is "human factor"
Sorry, i did not mention reason of problem, as try avoid explain thing which i am also not understand.
                                     > reason is human factor
 I beg to differ in opinion - one of the outputs seen is :
 It probably has a bad flash : the part number (in bold) refers to a flash component, hence I think my argument still applies
   M.
               (https://pdf1.alldatasheet.com/datasheet-pdf/view/313133/EON/EN25Q32A-100HIP.html)
after few reload
we don't have any CRC
BootROM - 1.78
1. 3K
2. 2K (new)
3. 2K (proto)
4. Milos
5. 2KH
6. 3KVE (v-sku)
7. 3KH/3KA/4K
8. Duplo
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Milos
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
RST I2C0
NAND: 256 MiB
BSS: 0x3ffef704
Stack: 0x3f9c8f20
u-boot>>
Unknown command '' - try 'help'
u-boot>>
so. may be somebody know how to return board id ?
Cisco disable (or remove?) prog_pid from latest U-Boot .
I don’t think you will find that answer here. The ones that can answer that question is most likely the BU and dev’s and typically they will just tell you to replace it. Seems like if the ap reboots, you will end up where you first started. I personally wouldn’t waste my time on that faulty ap anymore.
-Scott
sure, after AP reboot - it again wait press 4
So you see where I'm getting at, eventually the ap will not function and is therefor not reliable.  It's time to just call it a day and get rid of that ap and get another.
-Scott
i am looking way to set board id , that's why i am in this forum
my be somebody know how to return to old bootloader which probably have prog_pid
Scott Fella
Just to add, the ap you have is defective and will no longer function.  Since you don't have support, then recycle it and find another replacement AP to purchase and to use.
-Scott
kholod
OK.
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Barbados-3K
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
NAND: 256 MiB
BSS: 0x3ffef640
Stack: 0x3f9cdf20
u-boot>
Board ID: 3K
Flags=00000000
EM Ignore: 0
u-boot>> help
cp - memory copy
exit - exit script
init_aquantia_phy-
md - memory display
ubi - ubi commands
Usage:
...u-boot>> reset
resetting ...
====== SET !=====
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Milos
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
NAND: 256 MiB
BSS: 0x3ffef640
Stack: 0x3f9cdf20
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 1
Using egiga1 device
Loading: ##
1.6 MiB/s
done
u-boot>> boot
Board ID: Milos
Flags=00000000
EM Ignore: 0
u-boot>> printenv
BOOT=part1
CASset=max
ENABLE_BREAK=1
MALLOC_len=5
MANUAL_BOOT=0
MEMORY_DEBUG=0
MPmode=SMP
autoload=yes
baudrate=9600
bootdelay=3
cacheShare=no
disaMvPnp=no
dnsip=**********
eeeEnable=no
enaClockGating=no
enaCpuStream=no
enaFPU=yes
enaMonExt=no
enaWrAllo=no
eth1mtu=1500
eth2mtu=1500
ethact=egiga1
ethmtu=1500
ethprime=egiga1
fileaddr=2000000
filesize=6887
image_name=part.bin
ipaddr=*********
limit_dram_size=yes
loadaddr=0x02000000
loads_echo=0
mtddevname=fs
netretry=yes
partition=nand0,2
pcieTune=no
pexMode=RC
serverip=**********
stderr=serial
stdin=serial
stdout=serial
u-boot>> boot
Done
Contents:
OK
Starting kernel ...
Welcome to Cisco.
CUT
AP2C33.110E.82B8>en
Password:
CUT
2 802.11 Radios
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Milos
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
NAND: 256 MiB
BSS: 0x3ffef640
Stack: 0x3f9cdf20
Done
Contents:
OK
Starting kernel ...
Welcome to Cisco.
CUT
CUT
Upgrading ...
Master:
Version : 0x0134
Source : bundle
Retry : 0x1
Shadow:
Version : 0x0106
Source : flash
Retry : 0x1
Blacklisted:
Version : 0x0000
Source : unknown
Archive done.
=== NOW 134=====
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Milos
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
RST I2C0
NAND: 256 MiB
BSS: 0x3ffef704
Stack: 0x3f9c8f20
Done
Contents:
OK
Starting kernel ...
Welcome to Cisco.
I'm in the same position.  I have a 1562I that is stuck on boot every time.  The AP is "Out of Warranty" so I really don't have anything to lose at this point.  The best part about this is this was an AP that we just pulled off of the shelf (new) as a spare to replace a dead AP and it failed on boot.  I don't have the CRC errors.  I can work through the process of reflashing the u-boot however I'm unable to find the any old files.  I'd like to get my hands on version 1.06 however it doesn't appear to be posted anywhere that I'm able to find.  Can someone point me in the right direction to this version that has the progpid in it?
-Josh
1.06 in very old tar firmware. so - download them and find way to extract.  hope this clear.
