Integrate Wireless LAN Controller with Windows IAS
craigvoice
Community Member
I would like to have internal users authenticate to Wireless LAN Controller Module using Windows IAS server. What option are there for me to present to users? Do they get a separate domain username/password box? Can it pass thru their existing domain login credentials if they already logged into Windows domain? Does any additional client/laptop software need to be installed?
Scott Fella
What you should do is configure PEAP and use the IAS so users can authenticate with their AD credentials.
This should help you:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080921f67.shtml
-Scott
SirAdam_2
Community Member
In the new software release (5) for the WLCs there you can include LDAP for authentication...nice option. SO the users can authenticate on the web interface with their active directory credientials.
