08-28-2002 02:13 AM - edited 07-04-2021 11:23 PM
Can anybody give me some insight into integration of WLSE with Cisco Works 2000 or HP OpenView. The problem is that in a organisation if i have 10 WLSE installed, as WLSE has a limitation of 500 APs, now how can i have a centralized management of WLSEs. I think it can be achieved if we can integrate it with Cisco Works 2000 or HP OpenView. I am not able to find any reference to it on cisco site.
Kindly help.
09-05-2002 01:44 PM
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cwparent/cw_1105/wlse/1_1/index.htm should be what you need
10-11-2002 09:44 AM
Currenty there is no Integration of WLSE with CW2K available. Though you can import devices into WLSE using the RME csv file. Yes, this sounds not good if you have more than 500 APs that you're trying to manage. In that case you'd need to deploy more than one WLSE in your network. But I'm sure that in the future versions of WLSE this fetaure may get added or WLSE may be able to support more than 500 APs. I'd suggest that for this, you should submit an enhancement request via yout local Cisco Account Team/SE.
