09-23-2014 02:18 AM - edited 07-05-2021 01:34 AM
Dear сolleagues,
I have a problem with 3 AP AIR-SAP1602I-E-K9:
Interface Dot11Radio0, Deauthenticating Station xxxx.xxxx.xxxx Reason: Sending station has left the BSS
i have WPA / TKIP and i update the drivers on our laptops and i try a lot of solutions but the problem persists
this is my configuration :
! Last configuration change at 21:22:36 UTC Wed Mar 3 1993 by Cisco
version 15.2
no service pad
service password-encryption
hostname AP1
logging rate-limit console 9
enable secret 5 $1$MNKV$SsjzhDbJ2be4LpcUAErZD1
no aaa new-model
no ip routing
no ip cef
dot11 syslog
dot11 ssid FORAMAG
vlan 1
authentication open
authentication key-management wpa
mbssid guest-mode
infrastructure-ssid optional
wpa-psk ascii 7 06570B25154F504F564545
dot11 ssid FOR_INVITE
vlan 100
authentication open
mbssid guest-mode
wpa-psk ascii 7 104C001C0B0117051901
username Cisco password 7 02250D480809
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 100 mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid FORAMAG
ssid FOR_INVITE
countermeasure tkip hold-time 0
antenna gain 0
stbc
beamform ofdm
mbssid
packet retries 128 drop-packet
station-role root
rts threshold 512
rts retries 128
no dot11 extension aironet
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.100
encapsulation dot1Q 100
no ip route-cache
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.100
no ip route-cache
bridge-group 100
interface BVI1
ip address 192.168.1.31 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.110
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
Tank you
Solved! Go to Solution.
09-23-2014 04:13 AM
I would test these clients by configuring WPA2/AES on a SSID & see if the behavior is same.
Rasika
**** Pls rate all useful responses ****
09-23-2014 04:13 AM
Rasika
09-30-2014 07:44 AM
Thank you thats it :)
