internet access not working through Cisco wireless controller on IPhone ios 14
AHMED_MAKBOUL
Visitor
we currently 6 AP connected to Cisco controller and every thing was working fine to client updated his iPhone to ios version
14 the iPhone join successfully  the SSID but the WiFi icon dont appears on the screen and no available internet and opened a case and they recommend to disable private mac address on thr
7 Replies 7
Sandeep Choudhary
Did you restart the IPhone ? if not then do it and check again.
Dont forget to rate helpful posts
Leo Laohoo
Who is "they"?
Scott Fella
There have been many issue on the Apple forum after the upgrade to iOS 14. I too ran into issues but it was the session timeout bug on the 9800 controllers being set to zero. What I would do is disable private address and test. I have that disable on certain SSID’s I have running at home. Then I would test with a new test ssid. First start out with just open and don’t enable any features, make it basic as possible. Then go to wpa2 psk and again test. See what works and doesn’t.
-Scott
i already applied those steps and configure new open SSID without any enabled feature and still the same issue
1. Also try to turn on Airplane mode and after 10 sec turned it off!
2. Did you setup the DNS in your DHCP pool, When a APPLE device did't get a DNS ip address, it would consider itself offline and don't show the WIFI icon.
As long as your device gets a dhcp address and can access or see devices on the same subnet, then wireless is working and the issue is somewhere in your infrastructure. If you have other devices that work and or other iPhone or iPads working fine, then it’s that one device.
-Scott
Rich R
- What controller?
- What version of code?
- What AP?
- What WLAN configuration?
- What do client debugs on the WLC show?  Have you run those debugs through https://cway.cisco.com/wireless-debug-analyzer/ ?
- Have you checked your WLC config using https://cway.cisco.com/wireless-config-analyzer/ ?
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
