Internet connection on a Wireless Vlan issue
James Simpson
Hi All
I am having an issue with a particular Vlan and SSID. I have an several access points that are autonomous and talks to a controller.
There have been no issues or changes made on the wireless controller. A few days a go the wireless connection to the internet has gone down.
the laptops still receive IPs from the DHCP, but there is no internet connectivity. as I am gettting the little yellow sign in the corner of my laptop
I have spoken to the provider and there is no issues on the other vlans and they are using the same break out
Scott Fella
I don't understand what you mean by autonomous talking to a controller? Do you have a WLC? Please provide some configuration and more detail also.
-Scott
I have a wireless controller - what screen shots are you after ????
Well really these commands off the wlc cli
show interface
show WLAN
Or else just a
show run-config
The port configuration on your switch to which the WLC is connected to.
-Scott
Scott Fella
One thing you can do is connect a wired laptop to that same vlan and see if that machine can get out or not. Could be a NAT issue or DNS.
-Scott
