% Invalid input detected at '^' marker.
mmrasel16
Hi all,
I am unable to run any command on Cisco Aircap 2702i.
After "enable" command, all other command returns with "% Invalid input detected at '^' marker."
I tried conf t, configure terminal, config ap etc. all the commands but no luck.
please help.
your AP may have installed lightweight OS. check OS version in AP
Good luck
KB
Rich R
A lightweight AP cannot be configured like an AP running autonomous IOS.
All config is done on the WLC (controller) only.
The AP runs CAPWAP and connects to the WLC to get config, IOS etc.
If you want to use the AP in autonomous mode search "convert lightweight ap to autonomous"
