IOS based wireless lan controller
sobin peter
Level 2
Level 2
Hi I have a WS-C3650-48PS with 03.06.06E (IOS based wireless lan controller) Can someone send me the configuration guide or quick start guide.
24 Replies 24
Hmm you can try this:
ap country OM
However, I will need to research whether European APs are compatible with Oman RF.
*edit*
This link shows that -E APs are compliant with Oman regulatory RF domain so OM should be good!
http://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
Cheers,
Ric
Please rate helpful / correct posts
Do these:
Switch# enable
Switch# show wireless country supported
Switch# configure terminal
Switch(config)# ap dot11 5ghz shutdown
Switch(config)# ap dot11 24ghz shutdown
Switch(config)# ap country OM
Switch(config)# end
Switch(config)# no ap dot11 5ghz shutdown
Switch(config)# no ap dot11 24ghz shutdown
Dont forget to rate helpful posts
I changed the country code to OM but getting the below logs:
But we can see the AP is registered in the WLC, the screen shot attached.
*May 9 13:34:27.435: *%LOG-3-Q_IND: 1 wcm: Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
*May 9 13:34:27.435: *%LWAPP-3-RD_ERR7: 1 wcm: Invalid country code () for AP f078.163c.af40
*May 9 13:34:27.435: *%LWAPP-3-RD_ERR9: 1 wcm: APs f078.163c.af40 country code changed from () to (OM )
*May 9 13:34:27.435: *%LWAPP-3-VENDOR_PLD_VALIDATE_ERR: 1 wcm: Validation of SPAM Vendor Specific Payload(155) with length=10 failed - AP f0:78:16:3c:af:40
*May 9 13:34:27.437: %CAPWAP-3-AP_PORT_CFG: AP connected port Gi1/0/2 is not an access port.
*May 9 13:34:27.438: *%CAPWAP-3-DATA_TUNNEL_CREATE_ERR2: 1 wcm: Failed to create CAPWAP data tunnel with interface id: 0xe1afc000000007 for AP: f078.163c.af40 Error Reason: Capwap Data Tunnel create retry exceeded max retry count.
*May 9 13:34:27.538: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm: Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
*May 9 13:34:47.537: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm: Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 2 times/sec!.]
*May 9 13:35:07.538: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm: Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 2 times/sec!.]
*May 9 13:35:56.374: *%LOG-3-Q_IND: 1 wcm: Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
*May 9 13:35:56.374: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm: Invalid AP event () and state (CAPWAP Join Response) combination
*May 9 13:36:02.043: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm: Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response)
Your AP is not connected to an Access Port. It needs to be configured as access and on the same VLAN as your wireless management interface.
Ric
run these commands on 36590:
Switch# ap name AP02 shutdown
Switch# ap name AP02 no shutdown
Also paste the output of this command:
show ap auth-list
Also make sure:
summarize the requirements if you really need/want to do this:
1. The access-point needs to be in the same VLAN as the wireless management interface of the 3650 switch.
2. The interface where the access-point is being located on/after needs to be in access mode.
3. Only one access-point per interface.
Normally by default its enabled ...if not then do it:
ap auth-list ap-policy mic
Both the management and AP in the same vlan 999.
interface GigabitEthernet1/0/2
switchport access vlan 999
switchport mode access
spanning-tree portfast
interface Vlan999
ip address 10.1.1.1 255.255.255.0
ip pim sparse-mode
FASCO-WLC-SW#show ap auth-list
Authorize MIC APs against AAA : Disabled
APs Allowed to Join:
AP with Manufacturing Installed Certificate : Enabled
AP with Self-Signed Certificate : Disabled
AP joined status attached.
*May 9 14:10:33.637: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up
*May 9 14:10:34.370: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.1.1.1 on interface Vlan999
*May 9 14:10:56.759: *%CAPWAP-3-ECHO_ERR: 1 wcm: Did not receive heartbeat reply; AP: dceb.94bf.f034
FASCO-WLC-SW#
*May 9 14:11:32.367: *%CAPWAP-3-DUP_AP_NAME: 1 wcm: AP with same name APdceb.94bf.f034 exist. Using default name APdceb.94bf.f034 for this AP.
*May 9 14:11:37.641: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to down
*May 9 14:11:38.639: %LINK-3-UPDOWN: Interface Vlan999, changed state to down
*May 9 14:11:38.641: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2, changed state to down
*May 9 14:11:41.448: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2, changed state to up
*May 9 14:11:41.449: %LINK-3-UPDOWN: Interface Vlan999, changed state to up
*May 9 14:11:42.449: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up
*May 9 14:11:43.368: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.1.1.1 on interface Vlan999
Check the country code you configured on 3650 controller.
paste the output of sh version form AP.
show wireless country configured from 3650..
