IP addr not registering correctly
theophile
Level 4
Level 4
SInce we've upgraded our 8500 to firmware 8.0 (previously 7.4), the logs are filled with a lot of this message:
DHCP Socket Task: Nov 18 09:05:02.792: #DHCP-4-IPRGSTR_MSCB_FAIL: dhcp_proxy.c:1938 Registering IP on mscb failed for statione0:94:67:07:b1:da
*DHCP Socket Task: Nov 18 09:05:02.792: #APF-4-NOT_REGISTERING_IP_ADD_ON_MSCB: apf_foreignap.c:1873 Not registering IP address 10.231.14.31 with netmask 255.255.255.240 for client e0:94:67:07:b1:da
*DHCP Socket Task: Nov 18 09:05:02.792: #DHCP-4-IPRGSTR_MSCB_FAIL: dhcp_proxy.c:1938 Registering IP on mscb failed for statione0:94:67:07:b1:da
Mainly all of our clients get an IP address for a while then disconnect then try to get another one etc. The connection is not stable at all. When looking at the client part of the wlc, the client is noted as 0.0.0.0 althought when doing an ipconfig of the laptop, the laptop has an IP addr.
We didn't change anything in the wlc's configuration since the upgrade, nor in the netwoirk architecture (dhcp, radius). The wlc is acting as dhcp proxy.
I tried to find an explanation on google but no result. Any help will be really appreciated!
Théo
Thanks for the update
8.0MR1 would be a Christmas gift  from Cisco to the customer running 8.0.100.0
Rasika
5 Replies 5
mohanak
Error Message    %DHCP-4-IPRGSTR_MSCB_FAIL: Registering IP on mscb failed for
station[hex]:[hex]:[hex]:[hex]:[hex]:[hex]
Explanation    Registering IP on the mscb failed.
Recommended Action    Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://tools.cisco.com/Support/BugToolKit/. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/launch.do, or contact your Cisco technical support representative and provide the representative with the information you have gathered.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/message/guide/controller_smg/msgs4.html#wp1000716
Sandeep Choudhary
Hi Theo,
Something Client automatically(Many deuath...) goes to excluded list.
1. So first disable exclusion client from WLAN advanced page.
2. Try to connect the client again.
3. Check if mac filtering is enabled on wlan..and client is not added in mac list.
4. If client is not in excluded list then try to reboot the WLC and try again.
Dont forget to rate helpful posts
theophile
Level 4
Level 4
We've worked with cisco TAC yesterday and we're facing CSCur00288 : 8.0.100.0 client is shown with "ip address unknown" and "dhcp required".
This bug will be resolved in WLC 8.1 which is expected to be released by the end of this year.
Théo
This bug also affects local mode APs.
We've just faced with the same issue with WLC 5508 and APs working in local mode.
Rasika
