Iphone and IPad clients are afcing issue with wireless
Dear Team,
In my company, I have Cisco wireless controller 5508 and LDAP access points, I have created one SSID with radius authentication, radius server configured in on premises windows server 2008 R2 virtual machine. If I try to connect by using Windows Laptop , Samsung devices are working fine.If I tried by using IPhone or IPad, It's keep pop up for certificate warning with trust and cancel option. If I trust the option so that I can access the internet otherwise it's fails with to access the internet. I have attached the screen shot FYI.
Kindly guide me to fix the issue.
Kabeer
Scott Fella
Kabeer,
This is normal for Apple iPhone and iPads.  You have to initially accept the certificate and that should be it  you should not be prompted to accept the certificate again.  This is why when you have multiple radius servers, you use the same certificate for client access on all radius servers
-Scott
-Scott
