IR1835 Ruggedized router WIFI6 module availability
All,
with the release of the IR1800 series ruggedized routers, it shows a WIFI6 pluggable module for these routers but CCW only has the blank cover for the WIFI slot. when will the WIFI6 module be available?
Steve Williams
2 Accepted Solutions
Scott Fella
You should reach out to your Cisco SE/Rep to get you this information.  Some info might be under NDA and can't be disclosed, I personally don't know this answer, but your Cisco rep and or Cisco VAR should be able to get you this answer.
-Scott
https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-ir1800-rugged-series-routers/nb-06-cat-ir1800-rugged-ser-rout-ds-cte-en.html#Formoreinformation says "Wi-Fi 6 module will be available on the IR1800 in 2HCY21" - that's sometime between July and December.
Scott Fella
-Scott
Thanks Scott, I was looking for the availability date but couldn't find it.
Nice find!
-Scott
