WLAN ID Question
benolyndav
Level 8
Level 8
Does the WLAN ID have to match on Foreign and Anchor Controllers just asking has at the moment they dont for a new WLAN I have created and will be creating a policy on ISE for matching WLAN.?
Also is it the Foreign or Anchor Controller that talks to ISE? can anyone show me a step by step please from connecting to SSID to full network access.?
Guide is still valid for AirOS
BB
balaji.bandi
Personally i do not believe so - it is the requirement  - is this OLD WLC or new Cat 9800 ?
here is some document hope this help you :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-1/Enterprise-Mobility-8-1-Design-Guide/Enterprise_Mobility_8-1_Deployment_Guide/WirelessNetwork_GuestAccessService.html
https://www.youtube.com/watch?v=_HY7fPsqqcE
BB
Its an 8500 series
BB
Follow the guides that balaji has provided.  There are many blogs and videos on how to create anchor SSID's and what is required and how it works.  There is also information on ISE integration and or any radius server with anchor controller and what ports need to be allowed if your ISE internal and your controller is in the DMZ.
Search the following:
cisco anchor controller firewall ports
cisco anchor controller configuration example
-Scott
