03-01-2023 05:54 AM
Hey there,
I have 5508 controller running with 8.5.151.0 with some legacy AP's and now I wanted to migrate to 9800 WLC and new 9120AXI AP's, unfortunately I can't go directly, I have to keep both the setup and to support for seamless roaming (to enable L3 roaming) planned to create a mobility tunnel between AireOS and 9800IOS Controllers.
I read one of the document we have to go with under 8.5IRCM 8.5.182.104 firmware.
Now the question is I have to install both images which is available under 8.5IRCM. (i.e., Cisco Wireless Controller AP Bundle Image for IRCM Deployment base on 8.5MR8 (8.5.182.0) & Cisco Wireless Controller Image for IRCM Deployment base on 8.5MR8 (8.5.182.0)), What happens If I have not installed the AP bundle image.
Solved! Go to Solution.
03-01-2023 07:13 AM
Your 5508 must be on the IRCM release version. Here is another doc if you need for reference:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_c9800_wireless_controller-aireos_ircm_dg.html
For your second question, you need the ap bundle after you upgrade to the IRCM release if your ap's are on that list which requires the bundle or else the ap's will not join the controller. See this post:
https://community.cisco.com/t5/wireless/cisco-wlc-5508-upgrade-with-base-amp-supplementary-ap-bundle/td-p/3798500
03-01-2023 08:22 AM
My bad... I replied on the other thread. Here was my response:
It's a seperate image and you would select code.
Click Download to download the software to the Cisco WLC.
A message indicating the status of the download is displayed.
| Note |
For Cisco 2504 WLC, Cisco 5508 WLC, and Cisco WiSM2, the Cisco WLC software image is split into two images: the Base Install image and the Supplementary AP Bundle image. Therefore, in order to upgrade, repeat Step 2 through Step 14 to complete the installation of both the Base Install image and the Supplementary AP Bundle image. Download the Supplementary AP Bundle image only if you are using any of these APs: AP802, AP803, Cisco Aironet 1530 Series AP, Cisco Aironet 1550 Series AP (with 128-MB memory), Cisco Aironet 1570 Series APs, Cisco Aironet 1600 Series APs, or all of these APs. |
| Note |
Ensure that you choose the File Type as Code for both the images. |
03-01-2023 07:13 AM
03-01-2023 07:26 AM
Thanks for the reply.!
AP bundle install is same as code install? I mean after installing the base image I have to install AP bundle in the same way by selecting the FileType as code for AP bundle as well.??
Thanks in advance.
03-01-2023 07:32 AM
No... they are separate. If you look at the downloads and look at the description and or the filename, you can see it states what the file is for. So you need to upgrade to the IRCM:
https://software.cisco.com/download/specialrelease/bc334964055fbd9440834f008e5aca34
Then you need to upload the ap bundle after you reboot the controller:
Supplementary AP Bundle Images for Cisco 5508 Series WLC Release 8.5. This bundle is mandatory to support AP802,AP803,AP1530, AP1550 , AP1570 and AP1600.
03-01-2023 07:39 AM
What is the FileType should I select for AP Bundle, is Code or image from the dropdown list in Download File page??
03-01-2023 08:10 AM
Should be. I don't have a 5508 available to me to check. Maybe screen shot it.
03-01-2023 08:13 AM - edited 03-01-2023 08:14 AM
Should be the same way as you download new code. This section on the guide explains it:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr5.html#upgrade-instructions_85
03-01-2023 07:33 AM
Same way, but read the release notes also:
https://www.cisco.com/web/software/280926587/163407/Release_Notes_8_5_182_105.pdf
03-01-2023 08:22 AM
| Note |
| Note |
03-01-2023 11:01 PM
@Scott Fella Thank you for your time.! got it.
03-02-2023 12:40 PM
@Hemanth Shanthapp do NOT use 8.5.182.104 - use 8.5.182.105 if you want to avoid problems.
Refer to TAC recommended link below and the field notice links below:
