Cisco WLC 5508 Upgrade with Base & Supplementary AP Bundle Image
Prakash1
Hello Guys,
We have some confusion about AP Bundle image upgrade.
Situation:
1.our Wireless controller is running with 8.2.166.0 version we are planning to move on 8.5.135.0.
2.we have running AP model is 2702,3702, and 1572.
3.i have read out release note for 8.5.135.0, that clearly says for 8.5.135.0 code we need AP bundle for 1570 series to bring back online after upgrade.
Workaround:
We have downloaded 8.5.135.0 image controller right now.
we have not download  AP bundle image to controller yet.
Question:
1.first we have to upgrade my controller on 8.5.135.0 base image ?
2.second once my controller are up and all AP are UP except 1570 series Access point, we have to download bundle image to my controller.
so i am really confused is this process will work or not please advice.Earliest Thank you.
7 Replies 7
Leo Laohoo
No.
Upload the base image to the controller. Once that's done, DO NOT REBOOT the controller and upload the Supplementary Bundle Image to the controller.
Only when both image have been uploaded do you reboot the controller.
First check out the Cisco TAC AIROS Recommendations website and make sure you book mark if for future WLC upgrade references. In the 8.5.x train TAC are recommending 8.5.140.0
Correct you need to install both the base and the AP bundle.
The config guide: https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-
guide/b_cg85/managing_software.html
The guide has a step After the controller reboots, repeat step 6 to step 16 to install the remaining file. So
from that the process is:
Upgrade the Controller to 8.5 and reboot
then install the AP bundle, which will probably require another reboot
Confirm everything online.
Hope this helps
*****Help out other by using the rating system and marking answered questions as "Answered"*****
This not works for me.
A controller was upgraded from 8.3.143.0 to 8.5.140.0 a couple of weeks ago.
(Cisco Controller) >show boot
Primary Boot Image............................... 8.3.143.0
Backup Boot Image................................ 8.5.140.0 (default) (active)
Now I would like to install ap bundle image because of some old (1602) APs, but I got this error message:
TFTP Code transfer starting.
TFTP receive complete... extracting components.
Checking Version Built.
Image version check passed.
Started In Place extraction of TLVs
Version mismatch RTOS:8.3.143.0 AP:8.5.140.0, Installation aborted
(Cisco Controller) >show ap bundle primary
Primary Version : 8.3.143.0
AP Supplement Bundle : Not Installed
Primary AP Image        Size            Supported AP's
ap1g1                   13120           AP700
ap1g2                   13080           AP1600
ap1g4                   23308           AP1850/1810
ap1g5                   19076           AP1815
ap3g1                   9948            AP3500
ap3g2                   14972           AP2600,3600,1700,2700,3700
ap3g3                   28364           AP2800,3800,1560
c1140                   8836            AP1140
c602i                   3864            AP600
(Cisco Controller) >show ap bundle secondary
Secondary Version : 8.5.140.0
Secondary AP Image      Size            Supported AP's
ap1g1                   13192           AP700
ap1g4                   25784           AP1850/1810
ap1g5                   22208           AP1815
ap3g1                   10168           AP3500
ap3g2                   15380           AP2600,3600,1700,2700,3700
ap3g3                   39336           AP2800,3800,1560
c3700                   14372           AP600
I think I got error message because of the different secondary image and ap bundle version. Is there any way to upload ap bundle image for the currenty active and running wlc image without need to reboot the wlc?
I tried another WLC in our lab (type 2504), I done the same procedure, and there is no error message during ap bundle upload, works fine.
1st step: upload from to 8.5.140.0
2nd step: reboot
3rd step: upload ap bundle image
4th step: show ap bundle all (everything is ok)
Edit: I tried to upload 8.5.140.0 to the production wlc again without reboot, I set boot point to 8.5.140.0 image (which is now marked as primary), and after that I can upload ap bundle successfully wittout any reboot.
Primary Boot Image............................... 8.5.140.0 (default)
Backup Boot Image................................ 8.3.143.0
Primary Version : 8.5.140.0
AP Supplement Bundle : Installed
ap1g1                   13192           AP700
ap1g2                   13652           AP1600
ap1g3                   15380           AP1530
ap1g5                   22208           AP1815,1540
ap3g1                   10168           AP3500
ap801                   8468            AP802
ap802                   9968            AP802
c1550                   10928           AP1550(128MB)
c1570                   13052           AP1570
c3700                   14372           AP1700,2700,3700
So it's resolved, thanks!
We followed steps marked on release notes for 8.5.161.0:
upload Base Install image
reboot
upload Supplementary AP Bundle image.
unable to reboot since 1600 and 1530 aps are continually downloading.
Release notes specify: "...in order to upgrade, repeat Step 2 through Step 14 to complete the installation of both the Base Install image and the Supplementary AP Bundle image."
but in my case it has been very bad desition...!!
You should be able to reboot, even if the others are continually downloading. Please note, I have not tested this.
silkperfume
I had a similar situation where I have WLC 5508 in HA- mode, which I as upgrading from 8.2 to 8.5.151 and also  I had few 1500  series Outdoor APs that required supplementary bundle image.
Cisco tech recommended the following
"First download the primary image >> Reboot the controller and then download the bundle image again you have to reboot the controller. "
BUT i read here in this forum that someone had suggested that we do not need to reboot to download the bundle image to the controller.
Thats exactly what i did and it worked just fine.
Here is what i did:
First of all I downloaded the base image to the controller and pushed that image to all my APs using command "config ap image predownload primary all ".
At this stage all my APs except the 1500 series (AIR-CAP1552E-A) outdoors got the image 8.5.151.
Some indoor APs didnot get the new image, So for them i had to reset them individually using command "config reset ap {AP NAME}" and then predownloaded the new image again.
At this stage : 8.5.151 was my primary image(default)and 8.2.166 was my backup (active) image in the controller.
And in the APS: 8.2.166 was my primary and 8.5.151 was backup image
Then, without rebooting the controller I downloaded the bundle image to the controller and pushed the primary image to all my 1500 series OUTDOOR APs and this time they all got the new image 8.5.151.
Finally using GUI of the controller, I rebooted both controllers and it took less that 5 minutes to come back and within 10 minutes all my 200 APS were associated to the controller.
Note: I didnot use the swap command for the APs to interchange the primary and backup image.
APs were intelligent and quick enough to change the image themselves as soon as the controlled came back with new image.
Hope this will help somebody out there.
Happy Days :)
Just for anyone who still hesitates on what to do:
I just updated a 5508 controller from 8.5.161.0 to 8.5.176.2 (an IRCM release) with AP bundle.
I downloaded the AP bundle to the WLC after the software download and without a reboot in between.
So download the software image to the controller, then download the AP bundle the same way, then reboot, then wait for APs to come back up.
