Is it possible to clear all DHCP leases in one WLAN?
Erick Calzada
Thanks for your help!
I'd like to know if I can clear all DHCP leases in just one WLAN through the Wireless LAN Controller.
Regards.
balaji.bandi
you can do by login to the controller : ( check the syntax available on controller,)
config dhcp clear-lease  all  or x.x.x.x (ip address)
BB
Thank you for your help!
My question is because I have a WLC with many WLANS, so I wanted to know if I have to clear DHCP leases in all the WLANS created, or there is a way to clear leases in just one of them.
As far as I understand, there are two options: clear all of them or one by one,
Regards.
