Is it possible to convert an Aironet AP to LAP ?
srt_SIIM94
I would like to know is it possible to convert a   Cisco Aironet AIR-AP1042N-x-K9 to LAP ?
Thanks for you answer.
P.Gargot
Leo Laohoo
Yes, it's fairly easy.  All you do is copy the RCV file from your TFTP server and into the AP, change the bootstring to boot the RCV file and reboot the AP.
Thanks for you answer. All Aironet AP can convert to LAP ?
( I read in the support, only many AP can convert to LAP :
Gamme Aironet 1500
Gamme Cisco Aironet 1250
Gamme Aironet 1240 AG
Gamme Aironet 1230 AG
Gamme Aironet 1200
Gamme Aironet 1130 AG
Gamme Aironet 1000
AP de la gamme Aironet 1140
    What do you think ?
    Here is a list of supported access points and minimum code.
    http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp98682
    -Scott
