Is it possible to create several management interfaces to WLC?
pa7u12345
Hello all,
Is it possible to create multiply management interfaces to the controller? For example to isolate ssh and https access from CAPWAP traffic and use different than the management interface (IP) for snmp etc.
Thanks!
5 Replies 5
Sandeep Choudhary
As per my knowledge u can not create more management interface.
If you have old controllers then u can create AP manager interfaces:
https://supportforums.cisco.com/docs/DOC-28149
Rasika Nayanajith
No, WLC have a single management interface.
For OOB management you can configure the service port in certain controllers like 5508,5760
Rasika
**** Pls rate all useful responses ****
Thanks for the both answers.
But what makes the management interface so special compared to another interfaces? How does the WLC differentiate the management interface from the rest interfaces?
Management is for all management, mobility, syslog, snmp, NTP type traffic. Dynamic interfaces are for client traffic and or radius traffic if enabled. Managemt also does client traffic if the WLAN is assigned to the management interface.
-Scott
adding to scott:
the management interface IP address is used for GUI and CLI access.
A dynamic interface is simply an interface that maps a WLAN to a wired vlan or subnet.
Dynamic interfaces to be used to control and secure the traffic on the WLAN just like you would use vlans and subnets on the lan for that purpose.
Interface Roles
1.Management interface: Used for in-band management, connectivity to AAA, and other enterprise services, and for Layer 2 (and Layer 3 on the 5508) AP auto-discovery and association.
2.AP-manager interfaces: Source IP address used for AP to controller communication and Layer 3 AP auto-discovery and association.
Note: AP-manager interfaces are not required on the 5508 WLAN controller.
3.Service port interface: Provides out-of-band management of the controller (GUI access to Controller Web)
4. Virtual interface: Used for DHCP Relay, Layer 3 security authentication, and mobility management
5. Dynamic interface: Supplies mapping of WLANs to VLANs on the wired network
