Is there a management over wireless bug in 7.2.110.0
tdennehy
Level 2
Level 2
Does anyone know if there's a bug in the code for management over wireless in 7.2.110.0?  I have it enabled, but cannot connect to it.  When I do a port scan and see ftp and http open - https does not respond.  It should be the other way around, with port 80 not responding and 443 should be open.
If there's a bug, does anyone have a workaround?
Thanks in advance...
Scott Fella
I have not run into that issue... are you trying to hit the managment interface or one of the dynamic interface?
-Scott
If your trying to hit the management from one of the dynamic interfaces you will need to issue the following command:
config network mgmt-via-dynamic-interface enable
-Scott
Am trying to hit the management interface from a dynamic interface on that controller.  Doesn't appear to be working correcty, even though it is enabled in the gui.
