Is there a reverse for....
Tony Davis
Level 3
Level 3
config ap primary-base controller_name Cisco_AP [controller_ip_address]
Once you config a primary controller to an AP, it would be nice to undo that configuration so that an AP is no longer locked down to a specified list of controllers.
Thank,
Tony
Darren Lynn
Off the top of me head I can't remember the CLI command but on the GUI you can just remove the config from the AP config.
WIRELESS AP section. Select the AP and in one of the TABS is the config for primary, secondary AP's
I am aware of the GUI options, but it's such a pain to do it this way. If the GUI is able to remove the config, there must be a CLI to do the same...
>>> darlynn 1/20/2012 5:45 PM >>>
Home ( https://supportforums.cisco.com/index.jspa )
Re: Is there a reverse for.... created by Darren Lynn ( https://supportforums.cisco.com/people/darlynn ) in Other Wireless - Mobility Subjects - View the full discussion ( https://supportforums.cisco.com/message/3540406#3540406 )
Reply to this message by going to Home ( https://supportforums.cisco.com/message/3540406#3540406 )
Start a new discussion in Other Wireless - Mobility Subjects at Home ( https://supportforums.cisco.com/choose-container!input.jspa?contentType=1&containerType=14&container=2043 )
This message is confidential, intended only
for the named recipient(s) and may contain
information that is privileged or exempt from
disclosure under applicable law. If you are
not the intended recipient(s), you are notified
that the dissemination, distribution or copying
of this message is strictly prohibited. If you
received this message in error, or are not the
named recipient(s), please notify the sender
and delete this e-mail from your computer.
ETMC has implemented secure messaging for
certain types of messages. For more information
about our secure messaging system, go to:
http://www.etmc.org/mail/
Thank you.
