Is there still a conversion bug in VXworks 12.04?
c.tenley
I wanted to know if the new VXworks image (12.04) fixed the issue that was in Vxworks 12.03 that prevented upgrading to an IOS image. I had heard that if you uprgraded your APs to VXworks 12.03 you could not upgrade to an IOS image...you had to go back down to VXworks 12.02 then upgrade to an IOS image.
smalkeric
Level 6
Level 6
Yes, this has been rectified and you can upgrade to IOS from 12.04 VXworks.
Response to this post, According to documentation you cannot upgrade 12.04 to IOS on a 350AP. Is this correct? We upgraded 200+ 350AP's to 12.04, now need to upgrade to IOS, can this be done?
Has anyone upgraded a 350AP running 12.04 to IOS?
Thanks.
- Ted
