ISE & Prime auto power up
is there any way to make ISE and CPI turned on automatically after power cut.
Leo Laohoo
Yes.  The behaviour of the hardware appliance during power outage can be changed in the CIMC.
Hello, i am using ISE 2.2. Which menu option in the CIMC can I change the auto-start after powerloss?
thank you
Scott
