Issue of upgrading TONS of AP1100 (SSC) to join WLC
n.poongsawad
Experts,
I encounted the issue of upgrading 300 Aironet 1100 series i.e. 1121 to newly bought WLC.
Problem is 1100 are using SSC cert that I must do " debug pm pki enable " on each of 300 AP upgrading to extract its key-hash then copy to Security>AAA>AP Policy and repeat for 300 times. It is the impossible task.
What would you recommend us to do the any other methods to achive the same goal?
All suggestions r welcome, Thx in advance.
Nipat.p
Scott Fella
Take a look at the upgrade tool
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161111
-Scott
Scott Fella
-Scott
Leo Laohoo
Careful now.  Make sure you go through the Software Release Support for Access Points to know which WLC firmware can support your old 1120 WAPs.
