3502e antenna connection
choclateer
                   The 3502e has 3 antenna terminals for each band. Is the order of connection to the antenna pigtails significant? The antenna pigtails are not marked ABC (just blue boots for 5GHz.)
George Stefanick
I think you might get a difference anwser on that question by different folks. Note that this is a 2x3:2 AP. This means 2 tx, 3 rx, 2 streams.
I think the tx are on the 2 outter bulk heads.
With that being said I would try and keep the placment as it is on the ap and dont cross them.
Amjad Abdullah
I fully agree with George,
Placement of the antennas should be kept the same.
Rating useful replies is more useful than saying "Thank you"
