Issue with C9800 interfaces on hyper-v
Ingénierie RCI
Hi !
I'm having an issue with the C9800 interfaces (on the Bengaluru 17.5.1 version) on an hyper-v setup.
My virtual machine can only have one giga interface on the hyper-v vswitch (untagged).
Is there any way to configure the giga1 interface so the AP's and the Wlan clients can go through this interface ?
I have tested many way but can't find the good port configuration.
Is there any way to do it like this ?
Otherwise, is it possible to configure two giga interfaces on two differents subnet as the firewall can handle txo subnetw with a secondary subnet on its vlan 1 ?
Arshad Safrulla
Did you try the below command?
wireless management interface Gig1
Assign the IP directly on the Gig1 interface. Please make sure that the default route is added correctly.
Unless it is a lab environment, what you doing is not recommended.
