Issue with Toshiba FlashAir on AP1142
Brian I
 Some time ago, I had FlashAir Wifi SD Card connecting to wifi without any issues...
Now, running with an AP1142, the WiFi SD card connects for approx 10 seconds (the is the time I get ping reply from it), and then the connection is dropped again.
What causes the drop ?
A bit of debug gives me:
Jan  3 08:25:07.728: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   ec21.e53c.eb9e Associated KEY_MGMT[WPAv2 PSK]
Jan  3 08:25:22.614: %DOT11-4-MAXRETRIES: Packet to client ec21.e53c.eb9e reached max retries, removing the client
Jan  3 08:25:22.615: dot11_auth_client_abort: Received abort request for client ec21.e53c.eb9e
Jan  3 08:25:22.615: dot11_auth_client_abort: No client entry to abort: ec21.e53c.eb9e for application 0x1
Jan  3 08:25:22.615: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ec21.e53c.eb9e Reason: Previous authentication no longer valid
Jan  3 08:25:22.618: %DOT11-4-MAXRETRIES: Packet to client ec21.e53c.eb9e reached max retries, removing the client
The FlashAir card is a "closed" system, so I cannot update drivers or similar - and the card runs the latest firmware available..
Any hints on what could be the issue ?
Brian
balaji.bandi
This loooks for me nothing seems to be wrong on the AP side, have you tried any other device like Laptop to produce the problem ?
I would not rely on only 1 device failure as issue, this could be end device issue, if all device not connecting to AP then that looks for me different issue.
AP1142 - retired long back in 2018.
BB
marce1000
 - As was already replied , 1142 is ancient , use modern wireless infrastructure ,
M.
