I have the following problem, i have a WLC 5508 running version 7.3.102.0. The problem i'm facing is that when i place a call with the 7925g wireless ip phone, everything works fine, the signal is perfect and the quiality of voice. But i have a problem when we star walking and roam to another AP. When the roaming occurs the call drops.
Previously we had 7920 and it was working perfect, also i right now i connect a 7920 it works fine, the problem is when using the 7925g.
Any ideas of what could be happening????
Thanks for your help
Tony
Solved! Go to Solution.
Hard to say without some debugs, but make sure you take a look at this support doc. This will have info on what works and what doesn't
https://supportforums.cisco.com/docs/DOC-26863
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Scott
Item no 2 of the link provided by Scott is very important. Check whetehr your 7925G is running on the latest software code.
The 1.4.2 firmware introduced a greatly improved scanning and roaming algorithm in the 792x phones. 1.4.3 introduces other critical fixes. If you are experiencing audio problems with your phones - never, ever run any firmware prior to 1.4.3.
Be aware that, for newer hardware revisions of the 792x phones, it is not possible to run any firmware prior to 1.4(3)SR1 - see therelease notes. Therefore, for new or RMAd phones, you can't run the old firmware, even if you want to.
Rasika
**** Pls rate all useful resposnes ****
I agree with Ras ..
A few things.
1. What security are you using on the phone
2. Did this work at one time and broke recently ?
3. Are all handsets doing this everywhere?
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
"Im like bacon, I make your wireless better"
