WCS Failure Impact Issue
Ling Wai Law
Community Member
Dear All,
Sorry for don't know the impact area when the single WCS was failure, also, have 2-3 WLC in same network.  Thanks.
6 Replies 6
Chris Illsley
Level 8
Level 8
If your WCS fails it should have limited impact, obviously you're going to lose logging and monitoring and also centralized management, but the WLCs run independently of the WCS.
Chris
Abhishek Abhishek
As per your query i can suggest you the following link to refer-
http://www.cisco.com/en/US/products/ps6305/products_tech_note09186a008082ea02.shtml
Hope this will help you.
Ling Wai Law
Community Member
Grateful for all of the information ! Thanks
Ravi Singh
Level 11
Level 11
It would impact you central monitoring and logging but your network will work fine.
Appreciate your information, thank you so much
Ravi Singh
Level 11
Level 11
