Issues with SmartPhones not connecting to Cisco LWAP infrastructure
johnruffing
Level 4
Level 4
Has anyone observed any issues in getting wifi-enabled smartphones to connect to the Cisco LWAP wireless infrastructure?
In this particular case, the system is operating essentially as a hot-spot (i.e.: No layer 2 security between the LWAP and the smartphone.)
One of the SmartPhone models having problems is the Samsung i730.
I found an FAQ at the Verizon site (attached):
Exerpt from:
http://support.vzw.com/devices/samsung_sch-i730/faq.html#item66 <http://support.vzw.com/devices/samsung_sch-i730/faq.html#item66>
"Why doesn't the i730 connect to my wireless access point (AP) /router?
The i730 supports wireless access points that transmit a 128bit preamble not 130bit preamble. Some wireless access points send a 130bit (i.e. Cisco, Linksys, etc). To address this issue you can upgrade the firmware in your wireless access point by simply going to the wireless access point manufacturer's website and downloading the latest firmware and upgrade instructions."
Full article:
http://support.vzw.com/devices/samsung_sch-i730/faq.html <http://support.vzw.com/devices/samsung_sch-i730/faq.html>
I am wondering what version of LWAP firmware would address the 128-bit issue.
Any thoughts?
John
smalkeric
Level 6
Level 6
Try out the latest firmware for the controllers 4.0.206.0. This might solve the issue.
