issues with WLC 9800-CL smart license
nporcelli
Hello community,
I am having lots of trouble with the licenses on a new 9800-CL version 17.6.3, this is the first time I am dealing with this device.
First the license page on the weui is not loading, snapshot attached.
Second I have the customer licenses loaded to the portal and associated to their on-prem SSM. I tried to configure the WLC to register to the on-prem but it seems not to be working, I followed the info from the following document
"Configure & Troubleshoot Catalyst 9800 WLC Licensing with Smart Licensing Using Policy (SLUP)"
I also attached the output from the following command to show the main config and the License status/logs.
I tested communication on port 443 to the on-prem and it looks ok (in the txt file).
I tried both smart transport method :
license smart transport smart
license smart transport cslu
on the on-prem I cannot see any registration attempts
anyone having similar problems?
thanks
Nicola
22 Replies 22
marce1000
 - Could you run (CLI/SSH) show tech wireless and have the output analyzed by : https://cway.cisco.com/tools/WirelessAnalyzer/ , check if anything comes up related to network configuration and or your licensing issues.
 M.
nporcelli
thanks for the info, did not know that tool. I tried but the tool is not giving me any report at all as if it was ignoring the input
attached the file I used
Nicola
marce1000
 - Remember that for https://cway.cisco.com/tools/WirelessAnalyzer/ , it needs the output from show tech wireless not simply show tech neither show license tech
 M.
nporcelli
silly me, thanks Marce1000, this time I got many messages, I will go through them and see if there is anything useful for this issue.
nporcelli
hello, I run the tool and from the results it does not seem to be any network or license configuration issue. can anyone confirm the configuration I am using is correct?
thanks
Nicola
Can you check something?
Your call home is configured with "destination transport-method http" but you tested on port 443.
Can you test on port 80 or change the "destination transport-method http" "to destination transport-method https" ?
SWRN22WLC01#show run | section call-home
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
SWRN22WLC01#
SWRN22WLC01#
SWRN22WLC01#
SWRN22WLC01#telnet 11.11.11.13 443
Trying 11.11.11.13, 443 ... Open
[Connection to 11.11.11.13 closed by foreign host]
SWRN22WLC01#
nporcelli
Thanks for your input Flavio,
but I have one question, there are several license smart transport types:
SWRN22WLC01(config)#license smart transport ?
automatic             Use default transport type.
callhome              Use the Callhome as transport.
cslu                      All future communication will use cslu url.
off                        Disable all communication from Smart Agent.
smart                   Use the Smart Transport.
the document I am following says to set type clsu, which I have tried, I also tried Smart as transport method.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217348-configure-troubleshoot-catalyst-9800-w.html
But my understanding is that the 9800 should not use the call-home method if the transport call-home is not configured. am I wrong? also I have used the call-home method with other devices and in that case I have had to configure a profile different from the default to use the on-prem  server, because the default profile would try to connect to CSSM through the Internet and this device does not have access to the internet, so it cannot communicate directly with CSSM.
am I getting this wrong?
Nicola
Seems right to me as well. If the device is not connected to the internet then you need to use the option with on-prim. The method you should use is callhome.
 I had some problems with callhome and on-prime server with switches and this WLC is basially a switch.  But most of problem I had was on the server side cause the device site there´s not much we can setup.
marce1000
      - Possible bughttps://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv40929 , you may want to contact TAC to further work on this.
 M.
nporcelli
thanks, guys, I think I will contact TAC and see what they say, will post their solution once I have one.
Nicola
Rich R
I'll be interested to hear what TAC say.
We abandoned on-prem server because it was taking more than a year to support features already released in IOS (they only seem to think about on-prem after releasing each new version of IOS instead of developing them in tandem for simultaneous release).  We wasted a lot of time getting on-prem set up (to meet security requirements) and then were forced to switch to direct CSSM access to be able to actually use the products (which security acknowledged was unavoidable)!
Presume you've configured trustpoint and revocation-check none as per the doc you linked above?
tfrechette
I'm having the same issue on 17.6.3 with the licensing page not loading on the WUI. Did you ever get a resolution for this?
The CLI info for licensing seems fine. Thanks.
No.
I also raised a ticket with TAC but the engineer told me he could not recreate the issue in lab.
Eventually I had to downgrade to version 17.3.5a, because I had other issues with WebAuth and this was not working with version 17.6.3. so I did not go any further with it. license works fine on 17.3.5a
Same issue, 9800-80
Licensing and webauth working in 17.3.5a after downgrade from 17.6.3
