Join Cisco AIR-AP3802I-E-K9 to 9115-AXI embedded controller
Tesfaye41175
We have exciting Cisco AIR-AP3802I-E-K9 access point and we have ordered 9115-AXi embedded access point and we wanted confirm if acess point can be managed by embedded controller
Hello @Tesfaye41175
 Yes, it does support. The print I took is from the last IOS version but you can check the whole document on the link below
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#c9800-embed-ctr-ap_support
able 5. Cisco Embedded Wireless Controller and Supported Access Points
IOS XE Releases Access Point Image Version Number Access Point Release Supported Access Points
Cisco IOS XE Dublin 17.11.1
17.11.0.155
15.3(3)JPP
Cisco Catalyst APs: 9130 (I/E), 9124 (I/D/E), 9120 (I/E/P), 9117, 9115 (I/E), 9105 (I/W)
Cisco Aironet APs: 1800I, 1815 (I/W), 1830I, 1840I, 1852, 2800 (I/E), 3800 (I/E/P), 4800
Cisco Catalyst Industrial Wireless 6300 Heavy Duty Series Access Points
Note
9166I, 9164I, 9162I, 9136I only with Cisco Catalyst 9k switches with Embedded Wireless Controller in SDA mode.
Rich R
Conveniently shown in the release notes too:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-12/rel-notes/ewc-rn-17-12-x.html#Cisco_Concept.dita_4e686689-db5f-464b-8157-92abcfd40028
Table 3. Cisco APs Supported in Cisco Embedded Wireless Controller on Catalyst Access Points
Primary AP
Subordinate AP
Cisco Catalyst 9115 Series
Cisco Catalyst 9117 Series
Cisco Catalyst 9120 Series
Cisco Catalyst 9124AXE/I/D
Cisco Catalyst 9130
Cisco Catalyst 9105AXI
Cisco Aironet 1540 Series
Cisco Aironet 1560 Series
Cisco Aironet 1815i
Cisco Aironet 1815w
Cisco Aironet 1830 Series
Cisco Aironet 1840 Series
Cisco Aironet 1850 Series
Cisco Aironet 2800 Series
Cisco Aironet 3800 Series
Cisco Aironet 4800 Series
Cisco Catalyst 9130
Cisco Catalyst 9105AXW
Cisco 6300 Series Embedded Services Access Points
