02-05-2019 09:19 AM - edited 07-05-2021 09:48 AM
Hello
i have a smple problem then i would some one help me to resolve because this is project urgent
AP1815 ( with 8.3.111) can ping Moblity Express 8.8.100 then i have router as a server DHCP :
1.1.1.0 /24 with ip address managment 1.1.1.21
i have some command in ME :
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.05 13:42:09 =~=~=~=~=~=~=~=~=~=~=~=
show ap join stats summary all
Number of APs.............................................. 2
Base Mac AP EthernetMac AP Name IP Address Status
00:fc:ba:67:49:c0 N A AP28AC.9E89.48E0 1.1.1.23 Not Joined
a0:93:51:17:94:00 N A AP780C.F0DB.2A90 1.1.1.24 Not Joined
(Cisco Controller) >show ap summary
Number of APs.................................... 0
Global AP User Name.............................. AP-SOTETEL
Global AP Dot1x User Name........................ Not Configured
Global AP Dot1x EAP Method....................... EAP-FAST
* prefix indicates Cisco Internal AP
(Cisco Controller) >show ap join stats detailed
Incorrect input! Use 'show ap join stats detailed <ap-mac>'
(Cisco Controller) >show ap join stats detailed ?
<Cisco AP Mac> Enter MAC address of the specifc Cisco AP.
(Cisco Controller) >show ap join stats detailed 00:fc:ba:67:49:c0
Sync phase statistics
- Time at sync request received............................ Not applicable
- Time at sync completed................................... Not applicable
Discovery phase statistics
- Discovery requests received.............................. 66
- Successful discovery responses sent...................... 0
- Unsuccessful discovery request processing................ 66
- Reason for last unsuccessful discovery attempt........... Layer 3 discovery request not received on management VLAN
- Time at last successful discovery attempt................ Not applicable
- Time at last unsuccessful discovery attempt.............. Feb 04 01:43:17.019
Join phase statistics
- Join requests received................................... 0
- Successful join responses sent........................... 0
- Unsuccessful join request processing..................... 0
- Reason for last unsuccessful join attempt................ Not applicable
- Time at last successful join attempt..................... Not applicable
- Time at last unsuccessful join attempt................... Not applicable
Configuration phase statistics
--More-- or (q)uit
- Configuration requests received.......................... 0
- Successful configuration responses sent.................. 0
- Unsuccessful configuration request processing............ 0
- Reason for last unsuccessful configuration attempt....... Not applicable
- Time at last successful configuration attempt............ Not applicable
- Time at last unsuccessful configuration attempt.......... Not applicable
Last AP message decryption failure details
- Reason for last message decryption failure............... Not applicable
Last AP disconnect details
- Reason for last AP connection failure.................... Not applicable
- Last AP disconnect reason................................ Not applicable
Last join error summary
- Type of error that occurred last......................... Lwapp discovery request rejected
- Reason for error that occurred last...................... Layer 3 discovery request not received on management VLAN
- Time at which the last join error occurred............... Feb 04 01:43:17.019
Ethernet Mac : 00:00:00:00:00:00 Ip Address : 1.1.1.23
--More-- or (q)uit
(Cisco Controller) >?
apciscoshell Go to AP Console
clear Clear selected configuration elements.
config Configure switch options and settings.
cping Send capwap echo packets to a specified mobility peer IP address.
debug Manages system debug options.
eping Send Ethernet-over-IP echo packets to a specified mobility peer IP address.
grep Print lines matching a pattern.
help Help
linktest Perform a link test to a specified MAC address.
logout Exit this session. Any unsaved changes are lost.
mping Send Mobility echo packets to a specified mobility peer IP address.
ping Send ICMP echo packets to a specified IP address.
reset Reboot (hard reload) options.
restart Restart (soft reload) the switch.
save Save switch configurations.
show Display switch options and settings.
test Test trigger commands
transfer Transfer a file to or from the switch.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.05 13:59:42 =~=~=~=~=~=~=~=~=~=~=~=
show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.8.100.0
OUI File Last Update Time........................ N/A
System Name...................................... controlleur
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2489
IP Address....................................... 1.1.1.21
Last Reset....................................... 0: unknown
System Up Time................................... 0 days 0 hrs 50 mins 52 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
--More-- or (q)uit
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Memory Current Usage............................. 30
Memory Average Usage............................. 30
CPU Current Usage................................ 2
CPU Average Usage................................ 1
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
Burned-in MAC Address............................ 78:0C:F0:DB:2A:80
Maximum number of APs supported.................. 50
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
(Cisco Controller) >show time
Time............................................. Mon Feb 4 02:00:54 2019
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Version.................................. 3
NTP Polling Interval......................... 86400
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 0.ciscome.pool.ntp.org Not Synched AUTH DISABLED
2 0 1.ciscome.pool.ntp.org Not Synched AUTH DISABLED
3 0 2.ciscome.pool.ntp.org Not Synched AUTH DISABLED
(Cisco Controller) >ping 1.1.1.23
Send count=3, Receive count=3 from 1.1.1.23
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.05 15:31:32 =~=~=~=~=~=~=~=~=~=~=~=
AP-SOTETEL
Password:**********
Warning: Missing TFTP/CCO params, Please Configure the Image Download Params
Welcome to the Cisco Mobility Express command line interface.
Only commands which are listed in the command reference guide for this release are supported.
http://www.cisco.com/c/en/us/support/wireless/mobility-express/products-command-reference-list.html
(Cisco Controller) >debug ca?
cac call-control capwap calea
(Cisco Controller) >debug capwap detail enable
(Cisco Controller) >*spamApTask0: Feb 05 16:39:26.420: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 packet received of length 258 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 Total msgEleLen = 229
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 Total msgEleLen = 152
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 108
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 103
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 98
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 45
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 78
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 28
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:26.422: a0:93:51:17:94:00 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:26.422: a0:93:51:17:94:00 Vendor specific payload from AP A0:93:51:17:94:00 validated
*spamApTask0: Feb 05 16:39:26.422: a0:93:51:17:94:00 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:26.422: a0:93:51:17:94:00 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:26.422: a0:93:51:17:94:00 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:30.824: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:30.831: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:45.079: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:45.086: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:54.579: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:54.586: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.586: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.586: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:54.586: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:54.588: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:54.588: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:54.588: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:55.884: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 packet received of length 258 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 Total msgEleLen = 229
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 Total msgEleLen = 152
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 Total msgEleLen = 108
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 103
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 98
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 45
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 78
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 28
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Vendor specific payload from AP A0:93:51:17:94:00 validated
*spamApTask0: Feb 05 16:39:55.886: a0:93:51:17:94:00 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:55.886: a0:93:51:17:94:00 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:55.886: a0:93:51:17:94:00 Vendor specific payload from AP A0:93:51:17:94:00 validated
*spamApTask0: Feb 05 16:39:55.886: a0:93:51:17:94:00 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:04.083: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.083: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.083: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:04.083: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.083: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:04.085: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:04.085: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:04.099: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.099: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:04.101: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:04.101: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:04.101: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:04.101: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:13.588: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:13.595: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.595: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:13.597: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:13.597: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:13.597: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:13.597: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:13.597: 00:fc:ba:67:49:c0 Total msgEleLen = 0
(Cisco Controller) >de*spamApTask0: Feb 05 16:40:23.092: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.092: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.092: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:23.092: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:23.094: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:23.094: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:23.094: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:23.099: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:25.353: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 packet received of length 258 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 Total msgEleLen = 229
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 152
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 108
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 103
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 98
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 45
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 78
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 28
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 5 msgEleType = 1048
b*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 40
ug *spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:25.355: a0:93:51:17:94:00 Vendor specific payload from AP A0:93:51:17:94:00 validated
(Cisco Controller) debug>
(Cisco Controller) debug>*spamApTask0: Feb 05 16:40:25.355: a0:93:51:17:94:00 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:25.355: a0:93:51:17:94:00 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:25.355: a0:93:51:17:94:00 Total msgEleLen = 0
(Cisco Controller) debug>*spamApTask0: Feb 05 16:40:32.599: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.599: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.599: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:32.599: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:32.601: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:32.601: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:32.601: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:32.607: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 Total msgEleLen = 0
capwap errors enable
(Cisco Controller) debug>capwap errors enable
(Cisco Controller) debug>*spamApTask0: Feb 05 16:40:46.866: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.867: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.869: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.871: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:54.809: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 packet received of length 258 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 Total msgEleLen = 229
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 152
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 108
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 103
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 98
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 45
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 78
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 28
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:54.811: a0:93:51:17:94:00 Vendor specific payload from AP A0:93:51:17:94:00 validated
*spamApTask0: Feb 05 16:40:54.811: a0:93:51:17:94:00 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:54.811: a0:93:51:17:94:00 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:54.811: a0:93:51:17:94:00 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:40:54.811: a0:93:51:17:94:00 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:54.811: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:56.362: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.362: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.362: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:56.362: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.362: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:56.364: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:56.364: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:56.364: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:40:56.364: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.364: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.368: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.368: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.368: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:56.368: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.368: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:56.368: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:56.370: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:56.370: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:40:56.370: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.370: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.863: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.863: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.863: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:41:05.863: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:41:05.865: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:41:05.865: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:41:05.865: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:41:05.865: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.865: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.870: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.872: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.368: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.370: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.374: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.376: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
q*spamApTask0: Feb 05 16:41:24.268: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.24:5248
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 packet received of length 258 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 Total msgEleLen = 229
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 152
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 108
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 103
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 98
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 45
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 78
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 28
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 58
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 49
So what are solution that allow AP1815 join to ME ?????,, and will appear in interface web ME 1815 ???????,
02-05-2019 05:10 AM
I send you message and a file ouput WLC
how syn time zone beteen AP and ME !!! CLI or interface web 1815
we are time tunisia so what i put time zone ( US ) !!!
and i would to tell what other i can doing !!
02-05-2019 06:15 AM
Please , i wait to help me and give me answer that AP appera in interface web !!
show ap join stats summary all
Number of APs.............................................. 2
Base Mac AP EthernetMac AP Name IP Address Status
00:fc:ba:67:49:c0 N A AP28AC.9E89.48E0 1.1.1.23 Not Joined
a0:93:51:17:94:00 N A AP780C.F0DB.2A90 1.1.1.24 Not Joined
(Cisco Controller) >show ap summary
Number of APs.................................... 0
Global AP User Name.............................. AP-SOTETEL
Global AP Dot1x User Name........................ Not Configured
Global AP Dot1x EAP Method....................... EAP-FAST
* prefix indicates Cisco Internal AP
(Cisco Controller) >show ap join stats detailed
Incorrect input! Use 'show ap join stats detailed <ap-mac>'
(Cisco Controller) >show ap join stats detailed ?
<Cisco AP Mac> Enter MAC address of the specifc Cisco AP.
(Cisco Controller) >show ap join stats detailed 00:fc:ba:67:49:c0
Sync phase statistics
- Time at sync request received............................ Not applicable
- Time at sync completed................................... Not applicable
Discovery phase statistics
- Discovery requests received.............................. 66
- Successful discovery responses sent...................... 0
- Unsuccessful discovery request processing................ 66
- Reason for last unsuccessful discovery attempt........... Layer 3 discovery request not received on management VLAN
- Time at last successful discovery attempt................ Not applicable
- Time at last unsuccessful discovery attempt.............. Feb 04 01:43:17.019
Join phase statistics
- Join requests received................................... 0
- Successful join responses sent........................... 0
- Unsuccessful join request processing..................... 0
- Reason for last unsuccessful join attempt................ Not applicable
- Time at last successful join attempt..................... Not applicable
- Time at last unsuccessful join attempt................... Not applicable
Configuration phase statistics
--More-- or (q)uit
- Configuration requests received.......................... 0
- Successful configuration responses sent.................. 0
- Unsuccessful configuration request processing............ 0
- Reason for last unsuccessful configuration attempt....... Not applicable
- Time at last successful configuration attempt............ Not applicable
- Time at last unsuccessful configuration attempt.......... Not applicable
Last AP message decryption failure details
- Reason for last message decryption failure............... Not applicable
Last AP disconnect details
- Reason for last AP connection failure.................... Not applicable
- Last AP disconnect reason................................ Not applicable
Last join error summary
- Type of error that occurred last......................... Lwapp discovery request rejected
- Reason for error that occurred last...................... Layer 3 discovery request not received on management VLAN
- Time at which the last join error occurred............... Feb 04 01:43:17.019
Ethernet Mac : 00:00:00:00:00:00 Ip Address : 1.1.1.23
--More-- or (q)uit
(Cisco Controller) >?
apciscoshell Go to AP Console
clear Clear selected configuration elements.
config Configure switch options and settings.
cping Send capwap echo packets to a specified mobility peer IP address.
debug Manages system debug options.
eping Send Ethernet-over-IP echo packets to a specified mobility peer IP address.
grep Print lines matching a pattern.
help Help
linktest Perform a link test to a specified MAC address.
logout Exit this session. Any unsaved changes are lost.
mping Send Mobility echo packets to a specified mobility peer IP address.
ping Send ICMP echo packets to a specified IP address.
reset Reboot (hard reload) options.
restart Restart (soft reload) the switch.
save Save switch configurations.
show Display switch options and settings.
test Test trigger commands
transfer Transfer a file to or from the switch.
02-05-2019 06:19 AM
Other information
AP ping with ME but AP not joind to WLC !!!
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.05 13:42:09 =~=~=~=~=~=~=~=~=~=~=~=
--More-- or (q)uit
--More-- or (q)uit
help Help
02-05-2019 12:32 PM
Here is the problem:
make sure your APs are on the correct VLAN and the same VLAN is allowed on the trunk port where ME is connected to.
Configuring the Switch Port
All access points, including the Master AP, in a Mobility Express network should be in the same L2 broadcast domain. Management traffic must not be tagged.
The switch port to which the Master AP is connected can be a trunk port or an access port and must be configured to trunk Native VLAN for management traffic. Data traffic must be trunked with appropriate VLANs for local switching as well.
Interface GigabitEthernet1/0/37 description » Connected to Master AP « switchport trunk encapsulation dot1q (Newer switches/CatOS don't require this command)
switchport mode trunk
switchport trunk native vlan 122 switchport trunk allowed vlan 10,20,122
The following is a sample switch port configuration for AP
Interface GigabitEthernet1/0/15 description » AP « switchport mode access switchport access vlan 122
02-05-2019 08:14 PM
Thanks , this fay i try to edit configuration switch from acces to trunk : then i tell if its ok
But i have a question :
1) AP ( 29 AP 1815) run 8.3.111 and ME run 8.8100 : have no problem that AP join to ME or ,ot !!!
2) how i van edit time zone for ME and AP : because i fom tunisia . this 06/02/2019 05:12
SO i can put the time zone exacte : athat allow synchrinzation
02-05-2019 08:27 PM
1) switchport trunk allowed vlan 10,20,122 !!!
i have a question vlan 10 , 20 122 ???????, vlan mode access every AP !!!!!!!!!??????,
2) Interface GigabitEthernet1/0/15 description » AP « switchport mode access switchport access vlan 122
i have question : for AP number 2 : i put the same commande acces with natve vlan 122 ??????????
i wait your anwwer because i must finished this project this day
thanks in advance
02-05-2019 08:42 PM
thanks in advance
02-06-2019 06:23 AM
The VLANs are for reference only and they may not be the same that you've on your network. If you are not well versed with this network configurations, it's always good to engage someone who knows about the network or contact Cisco TAC to get help.
02-06-2019 06:19 AM
1. It's always good to have ME and APs on the same code to start with. However, it's not possible all the time and you will end up having them running on different versions like you've now.
The master AP facilitates transfer of image from TFTP to the new AP which is added.
You can find the process from the link below.
2. A Network Time Protocol (NTP) server can be configured to synchronize date and time if one was not configured during the Wireless Express setup. You can add your switch or router as NTP server in ME.
A step-by-step process is documented here
For your country, a simple google search showed me:
Tunisia Time Zone- is abbreviated as CET(Central European Time)
Tunisia is GMT/UTC + 1h Standard Time
I think (GMT+1 Amsterdam, Berlin, Rome, Vienna) is correct for your time zone, but I may be wrong. Please review your time zone configs for other network devices or someone who knows your region can answer that.
Please go through the above Mobility Express Deployment Guide thoroughly and you can find all answers explained in detail.
Jagan
